What size are they supposed to be?
Cheerz freddy
. The 'retaining clip' looks like it has totally corroded into place
(I can be easily pleased
Hinckley wrote:Good work so far Freddy
The circlip in the master cylinder is steel - the cylinder is aluminium - with enough persuasion it will yield.
Both the steel and aluminium have corroded, the mixed corrosion reacts and sets like concrete - but is not as strong as it looks - I have had success using a hammer and old screwdriver to chisel it away.
Replacement is easier - if you can get one.
