running rough
BShaw
#16 PostAuthor: BShaw » Mon Oct 05, 2009 8:58 am
See Zed1015's ...... post faulty dyna s
Baza
#17 PostAuthor: paul doran » Mon Oct 05, 2009 12:40 pm
breakdown wrote:Hi, since the bike runs fine above 2k then mechanicly the engine should be sound, so that leaves the fuel system and the ignition system.
If your 100% sure that the carb is clean and ok, then the problem has got to be in the ignition system. When you say running rough does it backfire/ pop?
when the revs start to drop it backfires and pops
#18 PostAuthor: zed1015 » Mon Oct 05, 2009 1:21 pm
Same symptoms as mine. See my faulty dyna thread. Just happened one day with no warning. Bugger to start, Rough running up to 2500rpm then clears above that, spitting back at low revs. It's probably the Dyna packing up and missing sparks, thats if you are running a Dyna of course.
debben1
#19 PostAuthor: debben1 » Mon Oct 05, 2009 2:08 pm
Hello Paul, You have checked cam timing and valve clearance?, I doubt its anything to do with the carburation, I would check auto advance unit, wires from the pick ups to the coils and try replacing plugs, Regards, Steve
breakdown
#20 PostAuthor: breakdown » Mon Oct 05, 2009 5:02 pm
Right, On the earlier Zeds the advance unit is fully opened by 3k starts opening about 1.5k,( not sure with the elr anybody else know). If you connect a strobe light and check the timing marks with that. If the marks are erratic when the problem appears then it's definatly the timing that is stuck on full advance. if the strobe shows the marks are fine them it's recheck carb time.
#21 PostAuthor: paul doran » Mon Oct 05, 2009 6:56 pm
okay problem sorted
it was the carbs
I fitted the set from that animal of an ELR I bought recently and it starts and runs perfectly
idles okay too
breakdown
#22 PostAuthor: breakdown » Mon Oct 05, 2009 7:16 pm
Excellent :D . Crack open a can.
knut
#23 PostAuthor: knut » Mon Oct 05, 2009 7:32 pm
well done paul sounded like blocked pilots ,now you can start on mine :wink:
what,s there to say except we,re all mad on here.
#24 PostAuthor: paul doran » Mon Oct 05, 2009 7:47 pm
knut wrote:well done paul sounded like blocked pilots ,now you can start on mine :wink:
how is the recovery coming on Mick
BShaw
#25 PostAuthor: BShaw » Tue Oct 06, 2009 8:55 am
Check float heights now there off, pilots, and while you are at it check balance the old way. Was there any shite in the bowls ?
Good news you isolated it, It is nice to be able to take another set off the shelf so to speak and swap them over.
Sorted ready for winter.
Baza
Big Fluff
#26 PostAuthor: Big Fluff » Tue Oct 06, 2009 11:51 am
About time you got it sorted old timer :lol:
See at Staffs mate :wink:
#27 PostAuthor: paul doran » Tue Oct 06, 2009 3:03 pm
Big Fluff wrote:About time you got it sorted old timer :lol:
less of the Oldtimer Smokey
oh! and not if I see You first :lol: :lol: :lol:
