Pigford wrote:Cheers Kev........ May well investigate this furtherbe good to learn a new skill
yes it would given You dont have any skills at present
zed1015 wrote:Frame is made of reynolds 531 tubing and HAS to be Bronze welded (braze)
DON'T weld as the excessive heat needed to melt the metal will make it brittle and it will crack under load.
P.s silver soldering is not the same as Brazing and does not use the same filler material.
Rich wrote:zed1015 wrote:Frame is made of reynolds 531 tubing and HAS to be Bronze welded (braze)
correct - send it to someone who knows what they are doing.
