Anyone know what wheels these are ?
#16 PostAuthor: zed1015 » Fri Jun 29, 2007 5:08 pm
Wheels are CMA's and if you look close they should have ( C M A ) cast on them somewhere , Usually in the rear brake drum and behind one of the front disc's.
ade woollams
#17 PostAuthor: ade woollams » Fri Jun 29, 2007 5:47 pm
yes they look like 5 spoke CMA'S they also did 3 spoke both where a nice touch on the 9's.i had a set of lesters on my old 1000a1 those where the dayz ,pipers ect :D
z1bnackerkwacker
#18 PostAuthor: z1bnackerkwacker » Fri Jun 29, 2007 6:08 pm
Thankx, will have to dig it out of shed and have good look for marks..(but prob' won't find out till I strip for painting or change, if their hidden behind disk or drum)..
z1bnackerkwacker
#19 PostAuthor: z1bnackerkwacker » Fri Jun 29, 2007 6:16 pm
What did CMA stand for, if anything? : :?: :?: :?: - mag'- alloy :?: (my guess).
z1bnackerkwacker
#20 PostAuthor: z1bnackerkwacker » Fri Jul 04, 2008 6:07 pm
zed1015 wrote:Wheels are CMA's and if you look close they should have ( C M A ) cast on them somewhere , Usually in the rear brake drum and behind one of the front disc's.
I Have now removed rear wheel to fit tyre, inside drum has MADE IN JAPAN cast...Guess that rules CMA out ? :?? ..No idea where CMA were made..
Some more pic's..........
Thezedsintheshed
#21 PostAuthor: Thezedsintheshed » Fri Jul 04, 2008 6:24 pm
The wheels are definatly CMA ,the reason that there is " Made in Japan " cast into the reat brake hub is that it is an original Kawasaki 900 brake hub fitted into the CMA wheel casting.
When the wheels were made the basic wheel was an alloy casting and the original spoked rear hub was then turned down in a lathe and pressed / shrunk into the newly bored out CMA wheel casting. this process was only carried out for drum braked wheels , the disc braked wheels were cast up in one go.
Seem to remember that the wheels went out of production because the CMA company was a " one man band" and the bloke running the company popped his clogs in work and that was the close of bussiness so to speak.
Fairly sure that " CMA " were the initials of the bloke running the bussiness.
Somewhere in amoungst all the junk here I have got an old magazine article about the company , I will see if I can dig it out and post it on here.
It's not broke , just in bit's for a while !
z1bnackerkwacker
#22 PostAuthor: z1bnackerkwacker » Fri Jul 04, 2008 6:39 pm
Thezedsintheshed wrote:The wheels are definatly CMA ,the reason that there is " Made in Japan " cast into the reat brake hub is that it is an original Kawasaki 900 brake hub fitted into the CMA wheel casting.
Is there anything you don't know Phil you showoff :lol: ......
Bike back together and may make Pritchards tomorrow if he can fit me in (as long as it's not pissing down)........
P.M me if you post CMA article :wink:
P.S YOUR BRACKETS SAFE....... :roll: :roll:
RALPHARAMA
#23 PostAuthor: RALPHARAMA » Fri Jul 04, 2008 11:49 pm
That was a seriously interesting reply, Phil.
I look froward to hearing more. I'm amazed it was cheaper to machine an existing hub, than just machine out a bit o metal for the brake drum
Ralph Ferrand
Keefleaf
#24 PostAuthor: Keefleaf » Sat Jul 05, 2008 10:38 am
Try CMA wheels?If you look carefully,[ under layers of paint ],you should find I.D. mark.
z1bnackerkwacker
#25 PostAuthor: z1bnackerkwacker » Sat Jul 05, 2008 5:21 pm
Keefleaf wrote:Try CMA wheels?
Try CMA WHEELS :?: :?? :?? :?? ,
I'll study them closer one day, maybe somegthing behind front discs when I take front wheel off i'll have a look......
AL MARSHALL
wheels
#26 PostAuthor: AL MARSHALL » Sat Jul 05, 2008 6:38 pm
i thought cma stood for CAST MAGNESIUM ALLOY wheel :??
paulypaul
#27 PostAuthor: paulypaul » Thu Jul 17, 2008 3:17 pm
Hi, bit of a long shot, but I need a rear wheel desperatly for my 75 Z1B to get it through the MOT, as the brake drum is cracked on mine, its got alloys on at the mo but anything considered !! ta, Paul.
peterf
#28 PostAuthor: peterf » Fri Jul 18, 2008 8:27 am
I'm sure they are CMA's. I had a pair on my Zed in the 70's/ The rear wheel usually had the standard drum brake heat shrunk into the wheel housing.
Later models offered a disc option.
I don't think I have any literature on them but will take a look.
I remember visiting their factory, I think in Suffolk.
z1bnackerkwacker
#29 PostAuthor: z1bnackerkwacker » Sat Jul 19, 2008 8:31 pm
peterf wrote:I'm sure they are CMA's. I had a pair on my Zed in the 70's/ The rear wheel usually had the standard drum brake heat shrunk into the wheel housing.
Thnx...
w kerr
wel fair rep
wel fair rep
#30 PostAuthor: w kerr » Sun Jul 20, 2008 9:39 am
cma i recon
Wayne
wel fair rep im da dady... berty big spuds dats me
Users browsing this forum: Stugill and 73 guests
