Engine paint
#16 PostAuthor: Ginger Bear » Mon Feb 11, 2013 6:15 pm
Looks interesting!
http://youtu.be/-9qM9_6GMwA
Big Fluff
#17 PostAuthor: Big Fluff » Mon Feb 11, 2013 7:08 pm
Rhencullen wrote:
Big Fluff wrote:The Siminoz 'Tough Black' is even better that PJ1 I reckon.
Will have to give this Simoniz stuff a whirl guys, 'cos I'm sorely missing PJ1. Thanks for the heads up :)
Here ya go, bargain for 6 tins at just £28. http://www.ebay.co.uk/itm/370694765439? ... 1439.l2649
He sells gloss, satin, matt, 1 tin, 2 tin, 6 tin, 12 tin deals.... will even mix & match like he's done for me.
Regs, Will
jphaynes669
#18 PostAuthor: jphaynes669 » Wed Feb 13, 2013 7:10 am
I, ve used halfords engine satin black enamel, and the results are good, prep it well and it applies smoothly leaving a nice finish. Also the same paint is fantastic for refurbing your zed wheels, better than new I reckon.
Jeff.H
hanskloss
#19 PostAuthor: hanskloss » Tue Feb 26, 2013 6:58 pm
I'm about to spray my DR400 engine while it's in bits, is this Simoniz toough black good for air cooled cylinders? Couldn't see any info reg temperatures, not sure I'm looking at the right stuff ?
http://www.ebay.co.uk/itm/2-X-500-ML-SI ... 48414a24d4
#20 PostAuthor: zed1015 » Wed Feb 27, 2013 12:06 am
hanskloss wrote:I'm about to spray my DR400 engine while it's in bits, is this Simoniz tough black good for air cooled cylinders? Couldn't see any info reg temperatures, not sure I'm looking at the right stuff ?
Yes! That's it and the Sperex tough black is the same stuff.
Treat it the same as PJ1.
See my cafe racer thread for the finish as i have done all the engine in it.
hanskloss
#21 PostAuthor: hanskloss » Wed Feb 27, 2013 9:45 am
Zed thanks for the info, I've seen your build thread and that looks quality,
do you think electric heat gun instead of baking will do the job OK? I can't bake the cases properly as I haven't opened them (seals/gaskets all in).
#22 PostAuthor: zed1015 » Wed Feb 27, 2013 10:10 am
I have done small parts with the heat gun but i apply the heat opposite the painted side so that the heat radiates into the paint from the underside.
I also warm the part slightly to sweat out any moisture from the castings which give the paint a better key.
I have never just painted a cold complete engine for a cosmetic tart up so i don't know how long it will last in the long term.
The pj1 and simoniz etc is good stuff though so should stay looking good for quite a while if it's applied to a nice clean base.
stempy
High Temp
#23 PostAuthor: stempy » Thu Feb 28, 2013 6:53 pm
PUM 451
Re: High Temp
#24 PostAuthor: ADRIAN H » Thu Feb 28, 2013 7:30 pm
stempy wrote:Has anyone tried this one
http://www.ebay.co.uk/itm/SIMONIZ-VHT-T ... 416ac0d5e9
:roll:
It is a matt finish.
mike_p
#25 PostAuthor: mike_p » Sat Apr 06, 2013 9:12 pm
anyone used the simoniz 'Tough Black' satin paint on an exhaust ? works a treat on the engine.....I'm just wondering how hot it would go
#26 PostAuthor: z1bman » Sat Apr 06, 2013 9:25 pm
engine painted with wurth high temperature black
Big Fluff
#27 PostAuthor: Big Fluff » Sun Apr 07, 2013 7:57 am
mike_p wrote:anyone used the simoniz 'Tough Black' satin paint on an exhaust ? works a treat on the engine.....I'm just wondering how hot it would go
It peels off... I've been there.
Keefleaf
#28 PostAuthor: Keefleaf » Sat Apr 20, 2013 7:48 pm
z1bman wrote:wurth high temperature satin black
Tried to get some this week,..told they're no longer doing satin black ?
Best stock up on Simomiz chaps.
malmojoe
#29 PostAuthor: malmojoe » Sat Apr 20, 2013 8:12 pm
I've used this for my bikes. Used on jet engines and can be sprayed from a HVLP gun. Satin black, cost about £45 for a litre. Done a few exhausts with it too.
http://www.indestructible.co.uk/IP9036R1/
Users browsing this forum: No registered users and 105 guests
