Electrex race ignition problem. Anyone running one ?
#16 PostAuthor: zed1015 » Mon Dec 16, 2013 9:45 am
Pigford wrote:Can't you run a little 12v dry cell (Maplins) to aid starting? - Whack a diode in the system and it should be enuff to get the spark going from zero :?:
That's a good idea if it can be done without damaging the Electrex.
I'll be using a 12v dry cell for the horn anyway so an extra wire or two won't be a problem if it can be done.
neilbarrett
#17 PostAuthor: neilbarrett » Mon Dec 16, 2013 11:44 am
zed1015 wrote:I've never rode with lights in daylight anyway and have never had a problem in nigh on 40 years - touch wood.
I have fitted a brake light though to stop 'em running up my arse end .
once worked at drax power station and the safety officer was having ago at us ,I said ive never had a accident in my life,his reply was that makes the odds shorter on you having one now ,never forgot that,
#18 PostAuthor: zed1015 » Mon Dec 16, 2013 4:38 pm
Spoke to electrex and i need 220 rpm to get a spark so am buying their race alt that uses the same billet back plate but is slimmer so it will fit under the cover i made.
The bike will still look the same so no trickness lost :roll:
Un-used Z900 race ignition anyone ?
Users browsing this forum: No registered users and 139 guests
