Pigford wrote:Probably a bit of "end float"
Not end float it's to rhythmic, quiet as a mouse on idle as soon as revs applied it's very audible
wilsonsjw11 wrote:Warren,
That sounds like a good result.
What is the mileage on this engine![]()
Regards
Steve
warren3200gt wrote: So now I'm thinking it may be a blocked oil way to 3 and 4 exhaust cam bearing. This could have been due to the engine builder not cleaning them properly when he did all the work.Is there any way to check without stripping the entire top end assuming I have decent pressure from the pump? If I blow compressed air into the oil pressure check plug with the cams out it should escape at the cam bearings right? Or is there an easier and/or better way? Or is the only way stripping the top end right down?
alternatively, if I blow compressed air down the cam bearing oil way on 1 and 2 exhaust cam bearing oil way it should escape from 3 and 4 bearing oil way?
Users browsing this forum: No registered users and 108 guests
