Air correctionn screws ? any info please Z1r
#16 PostAuthor: zed1015 » Thu May 19, 2016 1:52 pm
Gus wrote:
zed1015 wrote:You can make your own out of M5 brass grub screws or threaded bar and some micro pcb drill bits.
IIRC 0.6mm is the size for the Z but you could make several sets of different sizes to fine tune to your particular set up.
Trickiest bit is not breaking the drills.
http://www.gwr-fasteners.co.uk/m5-slott ... 1740-p.asp
Could you tell me what sort of length the restrictor should be as I'm going to try and make some?
Cheers Gus
They are only 8mm to 10mm long .
It's the hole size that matters not the length.
You don't want to be tapping too deep in to the carb and damaging the original fixed jet.
Also don't worry if the drill bit wanders as it goes through.
The Ledar ones start off central but most times emerge towards the edge at the other side.
Gus
#17 PostAuthor: Gus » Thu May 19, 2016 2:20 pm
Excellent.
Thanks for that.
Much appreciated.
Gus
"Set the GRINDER on it"
Swirl
Re: Air correctionn screws ? any info please Z1r
#18 PostAuthor: Swirl » Wed Dec 20, 2017 12:59 pm
Good info
Users browsing this forum: kev edwards and 76 guests
