Kz900 camshaft bearings
thewormman
- Regular Poster
Re: Kz900 camshaft bearings
So I'm fitting the new OEM bearings and the cam seems very tight and will only move when I lever it, is this normal when new bearings are fitted?
thewormman wrote:So I'm fitting the new OEM bearings and the cam seems very tight and will only move when I lever it, is this normal when new bearings are fitted?
If this is with the valves in the head then Yes!.
You are working against the valve spring pressure.
thewormman
- Regular Poster
OK that makes sense, thanks just a bit paranoid I guess
