Desperate to identify these !!!
bigmac103
#16 PostAuthor: bigmac103 » Sun Apr 12, 2009 9:03 pm
They're identical to the 26mm that are on my Z900A4! apart from the idle adjuster being on top on mine.
Lost in the desert somewhere
#17 PostAuthor: zed1015 » Sun Apr 12, 2009 9:51 pm
I have sets from both z1r and 1000a .Both are identical externally as yours with idle adjuster underneath but z1r's are 28mm and 1000a are 26mm. I also have sets from gs1000 which are basically the same mikunis but have provision for idle adjuster on top and cable operated choke. Jetting sounds about right. Std Z1R 28mm has 112.5 mains and 17.5 pilots. So yours are probably 1000a 26's . As long as it runs ok why worry.
#18 PostAuthor: Rich » Mon Apr 13, 2009 7:53 am
Most likely 28s from a Z1000 D1 / A3 / A4. Take them off and measure them as said Suzuki had cable chokes.
Dodgy Z1B
#19 PostAuthor: Dodgy Z1B » Mon Apr 13, 2009 8:35 am
If they are suzuki just to ad to the debate gs750 didn't have a cable choke and looked very similar, is ther not any serial numbers etc on them.
compo z1r
carbs
#20 PostAuthor: compo z1r » Mon Apr 13, 2009 8:45 am
defo 28.mm z1r carbs :roll: :roll:
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
KWACKERZ1
#21 PostAuthor: KWACKERZ1 » Tue Apr 14, 2009 10:25 am
Z1000A1/2 hAD THE ADJSUETR AT THE TOP 28MM Z1R OR SIMILIAR JUST TAKE THEM OFF A MEASURE THEM THEY i WOULD BET THEY ARE 28MM.
