81 Z650 F2, carbs, fuelling, jets and pipes
#16 PostAuthor: zed1015 » Fri May 15, 2009 8:53 pm
Z650's never had flatslide carbs so google source of info must have a mis-print . Strange??. Otherwise set up and operation would more or less be the same but that is insignificant anyhow as you have the correct std roundslide carbs for your machine.
mick znone
#17 PostAuthor: mick znone » Sat May 16, 2009 8:00 am
m1ks wrote:Taffus, thanks for the links, PM sent.
Bshaw, will check everything as I go, full service on the cards too, something always do when I get a new un, don't think the valve timing is at fault though, from experience it seems like a fuelling problem, (have had similar with electricals but batterys new and everything appears OK that side)
Mick Z1A, how much does a refurb go for on a set of clocks?
Thanks again all for the responses
you're looking at £100 a clock Mick, you may be lucky with a set, i tried 3 clocks, all knackered mate. but you never know.
