Clutch cable fitted
Oil take offs fitted
Slimline APE oil top thingy fitted!
Is Vic There wrote:So Gents what are your best tips when making a fresh loom up?
zed1015 wrote:Cooler can go either way but I favour the hoses feeding in at the top if possible.
This has a few advantages.
1 - Oil will circulate quicker from cold as the cooler remains full of oil and won't drain down when stood.
2 - Due to the cooler holding oil this increases the systems oil capacity slightly.
3 - It usually keep the hoses away from the exhaust area.
Only minor downside is having to drain the cooler at oil change time.
000zeds wrote:zed1015 wrote:Cooler can go either way but I favour the hoses feeding in at the top if possible.
Vic did you change your mind
