GPZ1100B1 WINTER TIDY UP READY FOR SUMMER
Padders
#31 PostAuthor: Padders » Sun Oct 23, 2011 6:12 pm
Maybe next year Steve this year will jus tbe a tidy up next year I hope to fit CB1000 front and rear ends complete.
Anyway I managed to get a bit done today in between chores as per the pictures below.
Thats it for now until I get some more parts back from powdercoat, I will post some more photo's once I have made some further progress on the project.
Baldylocks
#32 PostAuthor: Baldylocks » Sun Oct 23, 2011 6:48 pm
Nice, looking 100% better already, good luck with the build, looking forward to seeing more bits bolted back on.
Bugger ! whose Idea was that!
'78 Z1r '79 z650/1100 '77 Seeley H**** 750 GPz1100 B2 '86 GSXR750R Ltd '97 KTM620 '76 S3a 400
Padders
#33 PostAuthor: Padders » Sun Oct 23, 2011 7:11 pm
As requested here is a picture of the back light section.
Padders
#34 PostAuthor: Padders » Wed Oct 26, 2011 7:46 pm
Just a quick update on the project I had planned on running a 4 into 1 but Taffus came up trumps with a set of standard B1 exhausts. They need a tidy up but being painted as standard I should be able to sort them. Thanks Mark.
The old girl is looking a bit bare now hopefully have the engine out at the weekend and the rest of the chassis stripped down then get the new frame on the lift. The freshly powdercoated engine cases are fitted just the cam cover and sump to get coated.
Andy M
#35 PostAuthor: Andy M » Fri Oct 28, 2011 10:38 pm
"Not too bad from a distance" means good to go in my book..... :wink:
Padders
#36 PostAuthor: Padders » Mon Oct 31, 2011 7:32 pm
Not much of an update sorry its been a busy weekend family wise. I did however collect the swingarm from the powdercoaters. Total transformation.
Before
After
Now fitted to the frame along with the standard shocks.
She's not a perfect restoration with re zinc'd bolts etc just a nice clean up. Next up rear wheel to fit once I have fitted the new bearings and sprocket then the front end.
ta ta for now
Baldylocks
#37 PostAuthor: Baldylocks » Mon Oct 31, 2011 7:47 pm
That's looking really nice, are you lifting the engine back in? respect if you are! cos I know they are effin' heavy! also I have found that if you use a copper wire wheel on zinc'ed bolts it protects them for quite a while and sort of makes them look like new...
Padders
#38 PostAuthor: Padders » Mon Oct 31, 2011 8:35 pm
Yes its a lift out job but I have friends with strong backs (well for now anyway) Once out I will give her a good look over whilst the cam cover etc is away being coated. Front yoke powdercoated then get the rolling chassis sorted before dropping the engine back in. Sounds easy typing it out!!!
Cheers for the tip on cleaning the bolts.
#39 PostAuthor: paul doran » Tue Nov 01, 2011 10:55 am
looking good Ian
did Your Powdercoaters blast the swingarm for You or did You remove the paint Yourself
Padders
#40 PostAuthor: Padders » Tue Nov 01, 2011 11:36 am
They blasted it for me Paul all I do is clean off the dirt old chain lube etc.
Padders
#41 PostAuthor: Padders » Tue Nov 08, 2011 6:33 pm
Been a few days since the last post so a quick update. Engine will be out of the old frame this week, a big milestone and a chance to get the front end sorted and a rolling chassis built up. I posted a wanted add on the site for a set of crash bars similar to some I had on my Unitrak many moons ago.
Mick (sockpuppet) came up trumps with an old set in need of some TLC for the grand sum of a Z1OC Beanie hat plus postage. (yes I paid for the beanie hat)
Before cleaning and powdercoat rusted in places where the plastic coating has come off. A couple of graze marks on the outer edges which I dressed down with a file before sending to Les the man that can when it comes to powder coating.
After
Next update will hopefully see a complete rolling chassis.
DDZ900
gpz1100
#42 PostAuthor: DDZ900 » Tue Nov 08, 2011 6:41 pm
looking "GOOD" ian :wink:
Gshub
#43 PostAuthor: Gshub » Tue Nov 08, 2011 7:42 pm
Give you some good imfo ,back in 81 when i was just 21 and thought I was
Eddie Lawson on my Z1000j1, I touched my engine bars down on a fast left hand bend and side stand ,scared my self shitless good old Pirelli phantoms :oops:...
wish i could ride like that now,"older & wiser but still here to tell the tale"..
I HAVE a RED AND WHITE Gs1000S
DDZ900
gpz1100
#44 PostAuthor: DDZ900 » Tue Nov 08, 2011 7:53 pm
Ha ! same here gshub i had a B1 many years back in lawson colours.harris performance pipe,gas flowed,right off the track (local lad raced it) i loved it ! allways on the back wheel & 3 figures anywhere i could :lol: rapid at the time :D
Padders
#45 PostAuthor: Padders » Tue Nov 08, 2011 8:09 pm
Know the feeling guys we were all a bit bolder and faster in the old days.
