Yet anuvver new project - How long will I keep it this time?
KWACKERZ1 wrote:looks like the only way is up!!
Needs a lot of work,
How many projects on the go now?
Harris,
W650
This z
mk2 ?
Should keep you busy over the winter months!
Mind you I cannot criticize, currently up to 4 of my own and have taken on someone else's
Harris is a slow burner - as it's burnt most of my savings
W650 is sorted - no more messing, just tidied it up a bit & riding it.
MkII - errrm, gonna play with it over winter
LTD - no rush, as and when............. gonna copy Ginger Bears bike
Crofty - can't charge for viewing as it's all posted on here !
Hinckley - Just joking about the GPz cam end-caps! My Mk.II Sprinter has a GPz head, a common performance mod for Zeds.
- RALPHARAMA
Where are you putting them all? Last time I visited you had too many bikes for your garage and that was a lot less
Ralph Ferrand
Got the missing engine mounts from D&K bikes, via eBay - no probs
Then decided to rip off the rear muddie & light unit and fit the neat one I had stashed in the garage........
......... looks good me thinks
Gonna clean up & re-paint the Jock Kerr 4:1 before fitting it to see how it looks - then strip out the rear end and bung the JMC & Z1 wheel in along with some proper shox.....
The more I look at this bike, the more I find that needs doing
Hey-Ho, way to go - gimme summink to play with for a while
Had a spare few minutes this lunchtime, so I had a play with my wheels........ seem to be drifting away from my original plan - too much temptation stashed away
These are some re-furbed Z900 forks I did a swap for, a few years back; re-chromed, new seals & oil.
This JMC is for a drum brake wheel, but not difficult to overcome.
I had a new disc for my old XR400 and its a nice chunky 4.5mm item, rather than the 3mm standard thing! Obviously this route would open up a can of worms - needing: spacers galour, 1-off sprox & axles, caliper adaptor plate, etc.....
- RALPHARAMA
I like the understated minimalism of this design
Ralph Ferrand
- Ginger Bear
- coldsummer
