A bit of a Tart Up
#31 PostAuthor: Pigford » Tue May 20, 2014 9:21 pm
If the discs are NOT completely true & square to the wheels axis - the discs will be "wonky" :lol: and most likely cause brake judder and pulsing - so make sure the disc seating faces are 100% clear of paint :!:
Rodders5019
#32 PostAuthor: Rodders5019 » Sat May 24, 2014 11:24 am
Pigford wrote:If the discs are NOT completely true & square to the wheels axis - the discs will be "wonky" :lol: and most likely cause brake judder and pulsing - so make sure the disc seating faces are 100% clear of paint :!:
Thanks Piggy I found this out the hard way with my previous A4 build.( Warped Discs ) So I have scraped all the paint off the wheels and now the discs. :wink:
Rodders PUM
( Z900 A4 )
Rodders5019
#33 PostAuthor: Rodders5019 » Sat May 24, 2014 11:40 am
Thing's are coming together now, Z-Power sent the seals and pistons to referb the calipers on Thursday . Yesterday I ordered disc pads from Z-Power and they came today, the engineering shop called to say the discs were done so I picked them up and spent the afternoon taking the paint off the backs of them ( Piggy :) ) I tried to put the calipers back together this morning but it aint going to plan :( so have given up for today and will try again tomorrow :??
Rodders PUM
( Z900 A4 )
Rodders5019
#34 PostAuthor: Rodders5019 » Sun May 25, 2014 9:23 pm
Well it's tomorrow now so after a blast on the REX I got down to trying to fix the A4. I managed to get the calipers back together again ( fingers X ) I then put the discs on the wheels only to find that who ever did it last time kcuf ti pu , it seems to have bolts with different threads holding them on so had to go though them to match bolt with thread :shock: :shock: ,also they had used some none standard soft bolts so I managed to strip the tread on one :evil: :evil: If I had hair I would pull it out :angry . Just need the swingarm back and it might look a bit like a bike again ( ho hum ) :(
Rodders PUM
( Z900 A4 )
Is Vic There
#35 PostAuthor: Is Vic There » Sun May 25, 2014 9:43 pm
Run a tap down the holes first, makes the job a lot easier :wink:
Rodders5019
#36 PostAuthor: Rodders5019 » Sun May 25, 2014 9:53 pm
I did :??
Rodders PUM
( Z900 A4 )
sanderz
#37 PostAuthor: sanderz » Mon May 26, 2014 11:21 am
Your being put to the test by the sound of things going on Rodders - stick at it, don't rush and im sure it'll come together for you.
Its looking real good, keep it going :up
Wots up DOHC
Rodders5019
#38 PostAuthor: Rodders5019 » Mon May 26, 2014 1:00 pm
[img][img]http://i1368.photobucket.com/albums/ag189/Rodders5019/DSC_0813_zpse5c0b474.jpg[/img]
Just a mock up of the A4 to show what it will look like eventually I hope ( still no swingarm ) [/img]
Rodders PUM
( Z900 A4 )
Rodders5019
#39 PostAuthor: Rodders5019 » Mon May 26, 2014 1:02 pm
Rodders PUM
( Z900 A4 )
Rodders5019
#40 PostAuthor: Rodders5019 » Mon May 26, 2014 1:04 pm
Rodders PUM
( Z900 A4 )
Rodders5019
#41 PostAuthor: Rodders5019 » Mon May 26, 2014 1:05 pm
Rodders PUM
( Z900 A4 )
Rodders5019
#42 PostAuthor: Rodders5019 » Mon May 26, 2014 1:07 pm
Rodders PUM
( Z900 A4 )
Rodders5019
#43 PostAuthor: Rodders5019 » Mon May 26, 2014 1:10 pm
[img][img]http://i1368.photobucket.com/albums/ag189/Rodders5019/DSC_0820_zpsa2c58b7a.jpg[/img]
I know it looks like a blue but it is Yamaha grey & Ducati silver onest [/img]
Rodders PUM
( Z900 A4 )
Rodders5019
#44 PostAuthor: Rodders5019 » Mon May 26, 2014 1:14 pm
I just put the Hagon on to give it the right look :D What do you think ?? grab bar or NO grab bar :shock: Also can't make up me mind weather to remove the rear mudguard or not :??
Rodders PUM
( Z900 A4 )
garyd
#45 PostAuthor: garyd » Mon May 26, 2014 2:45 pm
Grab rail...deffo.
