New Project 2011/2012 /2013/2014!!
ollie
#61 PostAuthor: ollie » Fri Feb 15, 2013 10:17 pm
:xbou more more more :bla
Z1parR
#62 PostAuthor: Z1parR » Sat Feb 16, 2013 8:24 am
Keep the pics coming Stu :drool :brav
0172 . Geoff Parr
z1000puddin
Paint set now on
#63 PostAuthor: z1000puddin » Mon Feb 25, 2013 6:43 pm
Paint set arrived today with me, well chuffed :D
Just a pity I had bought the wrong tank cap last year. I never even bothered to check it until today, when I unwrapped it :twisted:
I have ordered another from zpower, so should get it this week.
My pics doesnt do Sis work justice, I need to get a better camera & some sunshine.
Zed til Dead
PaulMceleney
Chunks
#64 PostAuthor: PaulMceleney » Mon Feb 25, 2013 7:36 pm
very nice
#65 PostAuthor: Pigford » Mon Feb 25, 2013 8:13 pm
Well Friggin' Lush :twisted:
z1000puddin
#66 PostAuthor: z1000puddin » Mon Feb 25, 2013 8:38 pm
Thanks guys,
I got some Vavoline 10w 40 today.So I will need to change this out for the semi synthetic, to see if this makes any difference to the clutch slip
But the bugger is, I have to remove my exhaust to change the bloody oil-
I Didn't really think of that one during the build did I :cry: :shock:
Zed til Dead
ollie
#67 PostAuthor: ollie » Mon Feb 25, 2013 11:28 pm
sure looks nice stu :wink: ,bet that looks even better in the sunshine ,hope the oil works :)
#68 PostAuthor: Pigford » Tue Feb 26, 2013 7:38 am
z1000puddin wrote:Thanks guys,
If that don't work - do what I did a few years back with my A2........ it used to slip at higher revs, so I just fitted a "Lock-up" clutch.... :P
Same plates for 8 yrs... no probs, 10k miles + loads of sprints too :lol:
(I only run proper wet clutch/bike oil though :wink: )
z1000puddin
#69 PostAuthor: z1000puddin » Thu Feb 28, 2013 8:39 pm
Well after changing the semi synthetic castrol for Vavoline.......
No bloody difference,So I whipped of the clutch casing and found that the clutch pressure plate was easy to spin !!!
It looked like the hydraulic clutch was still partially engaged !!
I stripped out the fibre & steel plates, I also changed out the needle bearing mushroom for a standard one.
I then stuck in my spare set of used barnett clutch fibre & steel plates.
I checked that the hydraulic clutch was releasing - It was.
Stuck it all back together & hey presto - No clutch slip or Drag -
Confused I am :?: :?: :?: :|
Then to cap all this, my rear brake- which worked perfectly 4 days ago, now hardly stops the rear wheel.It seems like I am getting air into the system, I think it might be the hose connection to the cylinder.So I will need to look at this before I try to get it MOTd
Oh the trials & tribulations :| :| :|
Stu
Zed til Dead
#70 PostAuthor: zed1015 » Thu Feb 28, 2013 8:59 pm
The needle clutch pusher is thicker than the std one.
Sounds like the push rod needed shortening to compensate.
The slave cylinders piston probably bottomed out in its bore when bolted up and permanently released the pressure plate.
Swapping the mushroom did the trick.
z1000puddin
#71 PostAuthor: z1000puddin » Thu Feb 28, 2013 9:08 pm
zed1015 wrote:The needle clutch pusher is thicker than the std one.
Yeah zed1015,
I had shortened the clutch pushrod by 4mm when I fitted the hydraulic clutch, but this could not have been enough.
I measured the bearing mushroom & it is about 3mm thicker.
Stu
Zed til Dead
kiwi kdx
#72 PostAuthor: kiwi kdx » Thu Feb 28, 2013 9:45 pm
bike is looking great!
how loud is it with that small baffel?
z1000puddin
#73 PostAuthor: z1000puddin » Thu Feb 28, 2013 10:29 pm
kiwi kdx wrote:bike is looking great!
Ehh VERY LOUD :shock: :shock:
Possibly too loud, I may have to look at baffling a bit more
Stu
Zed til Dead
kiwi kdx
#74 PostAuthor: kiwi kdx » Thu Feb 28, 2013 11:14 pm
haha i thought so......
im running a stock CRB1000 RR undertail in my GPZeleven, but im thinking the opposite ill need to open it up.
PaulMceleney
Chunks
#75 PostAuthor: PaulMceleney » Fri Mar 01, 2013 6:48 pm
my stainless steal exhaust for my z1000 made by dave exhaust craft was very loud when i first fitted it, not any more now there is a coating of carbon inside the exhaust so i would leave your exhaust as it is no need to change anything
