Z1000st Project
Simonic
Re: Z1000st Project
#61 PostAuthor: Simonic » Sun Nov 03, 2019 5:24 pm
Thank You for your help Sir. I'll try your method as they are stuck fast.
Re: Z1000st Project
#62 PostAuthor: Philippe » Sun Nov 03, 2019 5:29 pm
Hi Simonic
I hope you succeed. I'm not sure about turning clockwise or counter clockwise...see what happens when you turn the pivot shaft with the allen key.
Simonic
Re: Z1000st Project
#63 PostAuthor: Simonic » Tue Nov 05, 2019 6:04 pm
Managed to get these out with some effort. I'd left them to soak in penetrating oil.Fabricated a puller. Out they came. Repaired a damaged thread while i was there...
Simonic
Re: Z1000st Project
#64 PostAuthor: Simonic » Tue Nov 05, 2019 6:06 pm
Ok. These four loops at the base of the frame. Are they just for the centre stand or are they used fro something else as well?
Thank You Gentlemen
Re: Z1000st Project
#65 PostAuthor: zed1015 » Tue Nov 05, 2019 7:04 pm
Just the main stand.
Simonic
Re: Z1000st Project
#66 PostAuthor: Simonic » Tue Nov 05, 2019 7:07 pm
zed1015 wrote:Just the main stand.
Thank You Sir
Re: Z1000st Project
#67 PostAuthor: Philippe » Wed Nov 06, 2019 1:35 pm
Hi Smonic
it worked! Great that you could get them out.
I see you're getting to the frame now. The bolts for the main stand are the same as those for other Zeds but the main stand itself is different, its a bit higher so do use an ST main stand or the rear tire will hit the ground.
Simonic
Re: Z1000st Project
#68 PostAuthor: Simonic » Tue Jan 25, 2022 9:23 am
It's been some time since i've done any work on this one. In my defence is did a lot of work on the 71 Dodge before i sold it and have also recommisioned a ZX1100 that has been laid up since the mid 90's.
The engine was rebuilt some time ago by Graham Salter down in Batley and the other day i thought it was time to get the engine and frame back together.
The rest of the bike is in a few boxes which i am going thru at the moment.After all this time piecing it together is going to be fun !!
Re: Z1000st Project
#69 PostAuthor: Ultim8pc » Tue Jan 25, 2022 12:13 pm
I did mean to ask what you'd done with the ST. Glad it's getting some attention!
Simonic
Re: Z1000st Project
#70 PostAuthor: Simonic » Tue Jan 25, 2022 12:37 pm
Ultim8pc wrote:I did mean to ask what you'd done with the ST. Glad it's getting some attention!
I'm the first to admit it's long overdue! Nice to hear from you,i hope you are ok buddy !
Re: Z1000st Project
#71 PostAuthor: Ultim8pc » Tue Jan 25, 2022 2:09 pm
All good here. Just started doing my Z1a
