trick z1000
shocks
Just remembered where they are:
so here we go
length eye to eye, 360mm top eye diameter 14mm 20mm depth bottom eye 10mm 20mm depth. (the actual bush external diameters are 25mm )
See pics, if you need anything else let me know.
Phil
[img][img]http://i223.photobucket.com/albums/dd291/kwackerz1/pb2004.jpg[/img]
[/img]
[img][img]http://i223.photobucket.com/albums/dd291/kwackerz1/pb2006.jpg[/img][/img][/url]
so here we go
Phil
[/img]
brian 450 wrote:I have made the new top shock mounts and drilled one side of the frame out. I might try and weld it tommorow. The problem is i think i will be a bit rusty at welding as i have not done any since i braced the frame.
practice, practice, practice.....
There must be someone with a GS1000 near you rusting in pieces!
- Ginger Bear
Users browsing this forum: Bing [Bot] and 32 guests
