Z1000 Money Muncher
mick znone
#91 PostAuthor: mick znone » Fri Feb 27, 2009 10:41 pm
:wow that is very nice Bear. thought youd have a beer can as an end can :pist :envy
#92 PostAuthor: Ginger Bear » Fri Feb 27, 2009 10:50 pm
There's an idea Mick :idea: , if only I could get hold of a 'Stella Party seven' (drinking it would be fun :D :D ), then I could turn the empty can into a 'right Blunderbus' of an exhaust :lol:
#93 PostAuthor: Ginger Bear » Tue Mar 03, 2009 12:47 pm
Right then, a quick update.
Spent Saturday fitting a new grommet to the altenator cable. This in it's self has raised a few problems/questions all of it's own. You can read it in a bit more detail in this thread
http://z1ownersclub.co.uk/forum/viewtop ... fe95658f06
My main concern is the condition of the cables on my altenator. The insulation is very brittle & cracked. I want to be able to use this bike, not just take pictures of it, so I want/need it to be reliable. The thought of breaking down, or worse some sort of electrical fire fills me with woe.
Currently I have fitted heat shrink to the cables where they were cracked & all seem's ok for now, but I am gonna fit a new altenator & combined regulator/rectifier probably from electrex.
MOT is booked for this Friday, I will sort electrics after that.
#94 PostAuthor: Ginger Bear » Tue Mar 03, 2009 3:30 pm
Right, I've done the deed!
I have ordered a new generator/stator & combined regulator/rectifier from Electrex. £126.70 inc VAT & delivery, should be here tomorrow. :D
#95 PostAuthor: Ginger Bear » Fri Mar 06, 2009 6:20 pm
Got this today
Whoopie! :D :D :D
tlc
#96 PostAuthor: tlc » Fri Mar 06, 2009 6:32 pm
Congratulations on the MOT Ginge.
Surely a benchmark :!: :D
Taffus
#97 PostAuthor: Taffus » Fri Mar 06, 2009 11:16 pm
Well done! GREAT MILESTONE :D
mikey
#98 PostAuthor: mikey » Fri Mar 06, 2009 11:17 pm
Well done steve knew you do it :D
brian 450
#99 PostAuthor: brian 450 » Sat Mar 07, 2009 8:26 am
Well done mate :D
#100 PostAuthor: Ginger Bear » Fri Mar 13, 2009 5:21 pm
Thanks guys, for your positive comments on me MOT. Tax disc arrived this week, so it was out for the first blast in anger this afternoon :D Well I say a 'blast in anger' but more of 'shake down' really. I returned home after approx 1/2 a mile as I'd cut off the cable tie that was holding the clutch cable away from the zorst header whilst experimenting with me oil cooler. I do plan to order the proper clip, but have fitted another cable tie for now so I could carry on. I did about 25 miles altogether, which were most enjoyable. I would have done more, but this was a 'shake down' not a joy ride :cry:
First problem I have is the speedo has gotta be miles out, as I am running a 17" front wheel. I plan to get one of the cheap pushbike jobs, or 'borrow' the wife to be's Tom Tom to work out the 'variation' the hopefully get Mr Big Fluff to make me some nice new clock faces that will read the correct speed.
Second problem is the bike seems to be 'undergeared' ie reving it's nuts of, without going very fast. I am running a 15 tooth front sprocket & a 38 tooth rear. I cannot go any smaller on the rear, as the chain will cut through the swinging arm :( I have checked Debben's website & see they do a 17 & 18 tooth front sprocket. I will speak to them next week & see what they suggest. But I would be interested to know what gearing anybody else is running with 17" wheels.
Third problem, bike seems to get a bit 'wooly' or 'choked' when sat in traffic. I have 17.5 pilots, K&N's 1105cc Pilot screws were out 1 1/4 turns. I have wound them out to 1 3/4 turns now & will see what happens on the next run.
Fourth problem is a persistent oil leak from the sump. It comes from the part that is closest the the big 'O' ring. I have tried all sorts to date & was wondering if the 'O' ring was the wrong thickness & it's that that is stopping the sump sealing properly, or the sump has been skimmed. Any one else had this problem?
maralyn
#101 PostAuthor: maralyn » Fri Mar 13, 2009 5:57 pm
I've got a colourtune you can borrow if you want?
I know it's old fashioned, but I find it works a treat on adjusting idle mixtures.
Some days I wake up Grumpy.
..................Some days, I just let her sleep.
maralyn
#102 PostAuthor: maralyn » Fri Mar 13, 2009 6:01 pm
I just saw the picture on the previous page.
'Luv it to bit's'
Good job well done, you should be very pleased.
#103 PostAuthor: zed1015 » Fri Mar 13, 2009 7:22 pm
I'm running 17 / 33 on the z1r with 17''s. I did have 15 / 36 but it was like a crosser with the front coming up or massive wheel spins in every gear. I haven't got any prob's with the chain fouling the chunky zxr swinger though ? but i did put a polyethylene runner near the pivot just in case ( The black thing near the tax disc) Image
#104 PostAuthor: Pigford » Fri Mar 13, 2009 8:10 pm
GB, I can check mine for you if you want anuvver set of figures......
Got me new tyres fitted to me spare rims, so gonna whack them on, ready for the ACE run :twisted:
#105 PostAuthor: Ginger Bear » Fri Mar 13, 2009 8:25 pm
Piggy,
That would be good if you don't mind. looking at what Zed1015 is running I think I will go straight for the 18 tooth front.
Zed1015,
I think chain runs on swingarm cos I've jacked up the back, but I do have a nylon runner fitted & once I've got me fat arse on board it's really not a problem. Just don't want smaller sprockets as that would compound the problem, so a larger front I think is the way to go.
Maralyn,
Might take you up on the colourtune if this 'tweak' doesn't help. I want to get the thing at least partially run in, then stick it on the dyno. I also have a hankering for a set of Mikuni Flatslides, so don't want to waste too much time & effort on the current ones, & believe me, I already have!!
