z900 kh500do they share the same brakes
steve f
does the z900 and the kh500 share the same discs and calipers i think they do but not sure
SteveF, when you say Z900, are you refering to Z900A4 or Z1 series? I believe they are both different from the Kh500 caliper, however, you may find the Z1 series may fit with respect to front forks holding-bolt centre distances. The KH500 may also have ribs (Cooling?) cast into the body. There were several small changes between these models. For example, the piston/ pad size may be smaller on Kh500.
RegardZ.
RegardZ.
steve f
Garn 1 wrote:SteveF, when you say Z900, are you refering to Z900A4 or Z1 series? I believe they are both different from the Kh500 caliper, however, you may find the Z1 series may fit with respect to front forks holding-bolt centre distances. The KH500 may also have ribs (Cooling?) cast into the body. There were several small changes between these models. For example, the piston/ pad size may be smaller on Kh500.
RegardZ.
sorry i did mean the z900 A4 sure they share the same calipers and discs
- rickman CRR
http://www.buykawasaki.com/Scripts/ImgS ... F=P&ilRE=8
KH 500 caliper?......looks like its significantly different to Z900 A4
- rickman CRR
I think that link above shows a H1 model
however
Looks very similar to the A4......
So probably out the same parts bin.
however
- rickman CRR
steve f
