HARRIS 4-1 EXHAUST COLLETS
PETER KZ1A
#1 PostAuthor: PETER KZ1A » Thu Dec 17, 2009 2:39 pm
G'day blokes,I'm after the 8 collets for a Z1000 Harris pipe.
Are there any collets out there......
london calling
#2 PostAuthor: london calling » Thu Dec 17, 2009 3:04 pm
G'day Peter,have you tried using your existing exhaust collets ??
When I swapped my 4-4 Z900 exhaust for a Vance & Hines,I used the standard Z900 exhaust collets
Z-POWER in the U.K. (and I guess Z1 ENTERPRISES in the U.S.A.) can supply new ones if you're un-able to get a s/hand set.
Hopefully someone on here will be able to help you out. :wink:
Jack
PETER KZ1A
HARRIS 4-1
#3 PostAuthor: PETER KZ1A » Fri Dec 18, 2009 12:39 am
Thanks for the reply.The collets are same for 900 and 1000,same part #,the Harris pipe is a bigger diameter,guess I should contact Harris
london calling
#4 PostAuthor: london calling » Fri Dec 18, 2009 8:11 am
Hi Peter,Harris haven't manufactured the pipes for many years now but may be worth an email.
I assume that you've tried the collets you've got and they won't fit ??
I've got a Z1000 V&H with Z900 collets no probs.
Jack
Magnum1
#5 PostAuthor: Magnum1 » Fri Dec 18, 2009 4:52 pm
Norman Hyde took over the Harris Works Collection series. His site is here;
http://www.normanhyde.co.uk/search.php?tag=51
Rod
Never heard of a Harris Magnum
