Neutral light comes on in first gear any advice
Padders
#1 PostAuthor: Padders » Sun Feb 14, 2010 7:01 pm
Hi the Z1 I recently bought would not change gear and had a solid clutch. I stripped the clutch and put new plates in. the clutch works great now and gears can be selected no problem. However when in neutral the neutral light does not come on. but when I select first gear it comes on.
Any ideas and advice welcomed.
tlc
#2 PostAuthor: tlc » Sun Feb 14, 2010 7:08 pm
Older Kwaks had neutral at the bottom.
Maybe a mix up in there somewhere ?
#3 PostAuthor: Pigford » Sun Feb 14, 2010 8:07 pm
Take the bulb out :roll:
prowlerz1
#4 PostAuthor: prowlerz1 » Sun Feb 14, 2010 8:20 pm
check the plate behind the neutral switch maybe it has been bent or fitted incorrectly ... take the trans cover off if this is the case
73 z1 green
73 z1 brown
74 z1a brown
75 z1b red
75 z1b blue
76 z900 green
77 z1000 black
Zrx1200r
Padders
#5 PostAuthor: Padders » Sun Feb 14, 2010 8:25 pm
Cheers Martin I thought I would have to delve in behind the transmission cover but had my fingers crossed it would be another simple fix.
Chris this is a Z1 not a triple.
Mark I am lost for words your informative replies are always more than welcome. Just like a fart in a space suit. :lol:
london calling
#6 PostAuthor: london calling » Sun Feb 14, 2010 8:28 pm
Don't you mean like an old FART in a CARDIGAN :lol: :lol:
Jack
jimmock
#7 PostAuthor: jimmock » Sun Feb 14, 2010 10:48 pm
london calling wrote:Don't you mean like an old FART in a CARDIGAN :lol: :lol:
Come on give the guy a break.
Whats his dress sense got to do with the neutral light issue???
Then again on the other hand Padders it was a bit old fuddy duddy !!!
Jimmock.
Jimmock. :wnkr
I hate people I don't like !
nigel bessant
#8 PostAuthor: nigel bessant » Sun Feb 14, 2010 11:21 pm
[quote="PADDERS"]Cheers Martin I thought I would have to delve in behind the transmission cover but had my fingers crossed
Must be difficult to hold tools that way.
tlc
#9 PostAuthor: tlc » Mon Feb 15, 2010 7:19 am
Padders. I wasn`t being thick when I suggested the neutral at bottom thing.
Is it possible that the plate with the pin which makes contact with the switch is from an H2 ? Or maybe it has come loose or been assembled wrong ?
Padders
#10 PostAuthor: Padders » Mon Feb 15, 2010 7:45 am
I knew what you meant Chris just taking the pish.
#11 PostAuthor: Rich » Mon Feb 15, 2010 6:29 pm
You're not very good with gearboxes are you! Shift drum detent plate - or to you the funny washer on the end :roll: is in the wrong position
Padders
#12 PostAuthor: Padders » Mon Feb 15, 2010 7:28 pm
Cheers Rich and no I am not very good at gearboxes.
#13 PostAuthor: paul doran » Mon Feb 15, 2010 7:32 pm
Pigford wrote:Take the bulb out :roll:
ever the helpful soul Our Piglet :lol: :lol: :lol: :lol:
pertonpc
#14 PostAuthor: pertonpc » Mon Feb 15, 2010 9:06 pm
I don't know if this will be helpful but on my z650 there is a notch in the disc that rotates underneath the nuetral switch when you take the inner transmission cover off. That has to be directly under the switch when you are in nuetral to activate it.
You can see the raised notch on my one (its at the 9o'clock position) on the plate on the left spindle. I wonder if you have mounted that slightly offset??? From Mark
Padders
#15 PostAuthor: Padders » Mon Feb 15, 2010 9:30 pm
Cheers Mark that seems to be the problem. Looks like the previous builder made a slight mistake but its not the end of the world.
Users browsing this forum: Bing [Bot] and 21 guests
