now what ??
wayno
now what ??
#1 PostAuthor: wayno » Wed Feb 17, 2010 6:36 pm
just bought this http://www.electrexworld.co.uk/rr10-uni ... 527-0.html after reading threads and contacting electrex them selves so how does it connect up ?. using the green plug do i connect using bullet type conections on the 3 yellow, black to earth and red female to where? switched live or permanent? dont have a much of an idea so colours/what they supply would be good.
thanks wayne.
ruffle
#2 PostAuthor: ruffle » Wed Feb 17, 2010 6:44 pm
The yellows would be the three phases output from your alternator (doesn't matter which yellow goes to which phase).
The black will be earth. The Red provides positive yummy DC volts from your shiny new regulator and goes to the battery positive terminal.
Course, I'm a computer programmer not an Auto Electrician and this 'advice' is worth every penny you just paid for it :)
martinz1b
Re: now what ??
#3 PostAuthor: martinz1b » Wed Feb 17, 2010 6:45 pm
wayno wrote:just bought this http://www.electrexworld.co.uk/rr10-uni ... 527-0.html after reading threads and contacting electrex them selves so how does it connect up ?. using the green plug do i connect using bullet type conections on the 3 yellow, black to earth and red female to where? switched live or permanent? dont have a much of an idea so colours/what they supply would be good.
thanks wayne.
Just about to buy one myself so this will be interesting.
#4 PostAuthor: zed1015 » Wed Feb 17, 2010 6:55 pm
ruffle wrote:The yellows would be the three phases output from your alternator (doesn't matter which yellow goes to which phase).
Absolutely correct :up . You can also run the black (earth) direct to the batterys negative terminal if required.
02GF74
#5 PostAuthor: 02GF74 » Wed Feb 17, 2010 9:57 pm
not a bad price.
check my post on how to fit a rectifier/regulator unit, for a tenner.
you can always cut the wires and jpoion them on to the wieres from the pluyg.
you need to splay the wires, clean them with wet'n'dry, then push end to end, twsit for good contact then apply electrical solder. to stop the wires from unrave;lling, which they want to do, I use one thjiin strand to wrap round them holding them in place.
wayno
#6 PostAuthor: wayno » Sat Feb 20, 2010 4:53 am
got the wiring sorted so will fit it later if i get some time, i'm going to take the red direct to the pos on the battery so do just remove the brown pin on the plug and can i remove the rect completely or does it need modifying/leaving in place?
ruffle
#7 PostAuthor: ruffle » Sat Feb 20, 2010 12:13 pm
Eh? You don't need two reg/rectifiers or have I misunderstood?
#8 PostAuthor: zed1015 » Sat Feb 20, 2010 1:11 pm
Remove the old rectifier and regulator when fitting a combined unit.
