Ground Shims
ruffle
Ground Shims
#1 PostAuthor: ruffle » Fri Jul 01, 2011 12:25 pm
Back in the pre-meltdown days I was having problems with the shims in my Z1R after lightly grinding the valves took the clearances below tollerance.
I needed some 1.90's but all the previously mentioned Yamahaha sources for this size had de-listed them (Kawasaki only list them down to 2.00).
Several folk spoke of grinding down shims and PaulJ kindly sent me three that had already been ground; albeit not to the 1.90 I needed so I could try a bit more grinding myself.
Errr.... nice idea but it didn't work.
Trying to grind the shims further using grinding paste on a glass sheet (to keep it all flat) does pretty much bugger all (yes I was working on the previous ground side!). After half an hours effort I had managed to clean up the grinding marks on one shim but made naff all difference to the thickness.
So; unless you have access to some mechanical surfacing grinding kit; don't bother trying to do it by hand.
What did I end up doing? Tipping the valves as suggested by Jerry(?) and detailed in the workshop manual got them back into the range where normal shims could be used.
Garn 1
#2 PostAuthor: Garn 1 » Sat Jul 02, 2011 9:13 pm
Rufflel, a good point, however, before getting all your valves "tipped", it a good idea to check them in the head with cams to see you do not have to put a 300 (3mm) or greater shim in!
This check is carried out by assembling buckets and valves without springs, with say a 200 (2mm) shim in place and measuring the clearance, whilst apply pressure (by hand) on the valve head to the cam. Then measure the gap.
I say this, merely because, I once sent a set of valves to be faced & tipped and the machinist was a bit ambitious and machines too much off. Resulting in two things.... too bigger shims required and tops of valve collet had to be relieved. I now say, take a bare minimum off the tip.
RegardZ.
ruffle
#3 PostAuthor: ruffle » Sun Jul 03, 2011 8:29 am
Good advice. I took about 0.2-0.3 off each valve so the ones that needed 1.90 went
to needing ~2.20's.
The workshop manual gives a minimum distance twixt the top of the valve and the
collett groove and I was well over that.
My big lesson learnt is that you should do a 'dry' build of the head on the bench
and check the cleanrances before bolting everything back onto the bike.
