Z1 Forks
DogsbolloxofZ1B
Z1 Forks
#1 PostAuthor: DogsbolloxofZ1B » Mon Jul 25, 2011 9:44 pm
Can anyone recall if the fork tube slides all the way to the bottom of the stanchion:?:
I've got a set of '72 forks on the bench at the moment, stripped all the damper rods etc. When I insert the new tubes they stick approx 100mm from the bottom and both sides are the same. Its been a while but I'm sure they should reach the bottom without being forced. Nothing in the manual either.
I've bought a Silicon carbide honing bar especially for the job but just wondered if anyone else had come across this? The internals look a bit grotty near the bottom maybe water contaminated the oil in the past.
Cheers,
Mike
#2 PostAuthor: z1bman » Mon Jul 25, 2011 10:18 pm
i had this problem on my z1b but only on one side i purchased another lower fork leg + this cured the problem. you should hear a clonk when the fork inner tube reaches the bottom of the for leg
DogsbolloxofZ1B
#3 PostAuthor: DogsbolloxofZ1B » Mon Jul 25, 2011 10:25 pm
Thanks. I can't any reason why they wouldn't reach the bottom and the clonk is pronounced on some early Z1's.
I'll get the honing tool fired-up :D
GEZ635
#4 PostAuthor: GEZ635 » Sat Jul 30, 2011 8:30 pm
I always find non genuine sliders always stick and need a bit of a hone.The trouble when chroming tubes is there is normally more chrome at the ends of the tube. Dont know why this happens buy I have had it lots of times.
Gez
DogsbolloxofZ1B
#5 PostAuthor: DogsbolloxofZ1B » Sun Jul 31, 2011 9:22 pm
Gez,
Thanks. I linished the ends of the forks after honing the bore in the sliders and all's well, at last..
Mike :shock:
#6 PostAuthor: kev edwards » Tue Dec 13, 2011 11:10 am
GEZ635 wrote:I always find non genuine sliders always stick and need a bit of a hone.The trouble when chroming tubes is there is normally more chrome at the ends of the tube. Dont know why this happens buy I have had it lots of times.
It's called dog boning and is because the current density is higher at the contact points when electroplating.
