Slotting cam wheels
Slotting cam wheels
I will need my cam wheels slotting for my Z810 engine, is this a machine shop job or is there a reliable way to do it myself? Crofty
I slot my own with a small round file.
The cam sprocket metal is soft.
Put the sprocket on the cam without any bolts and rotate the sprocket on its stub whilst scribing through the bolt holes.
That way you get the correct arc for filing the slot.
You don't need to take much off, Just enough to move the sprocket in the range of one tooth.
zed1015 wrote:I slot my own with a small round file.
did the same thing years ago, i used a chainsaw sharpening file which was spot on
Ok, just had a go at filing it and Rob was right, the gears are pretty easy to file. Filed one hole out in around 15 mins. Gear rotates enough either way to get nearly one tooth either way. Can always file a bit more if needed when the time comes.
I will need to have some metal machined off from around the bolt head recess to allow bolt head to sit flat against the wheel though.
Vid of one slot done
and pic of both wheels done
