gasping for air
gasping for air
#1 PostAuthor: paul doran » Thu Aug 04, 2011 4:05 pm
I am currently working on a Z1 at present
I have tuned the carbs balance etc
colourtune is good on all cyclinders
but unless I remove the air filter when I rev it it is gasping for Air
ideas please
zman
#2 PostAuthor: zman » Thu Aug 04, 2011 4:48 pm
Had similar problem.Was a combination first removed my K&N filter and put in new standard one.Also i found at prolong full speed there was a fuel feed problem.
keep thoses wheels turning
#3 PostAuthor: Rich » Thu Aug 04, 2011 5:17 pm
needle jets knackered,
airways / air jets blocked
air filter knackered
Poor ignition
DogsbolloxofZ1B
#4 PostAuthor: DogsbolloxofZ1B » Thu Aug 04, 2011 7:52 pm
You could look into changing the pilot jets on the intake..
http://www.motocarb.com/carbs%20and%20parts.htm
Mike
Blackfox
#5 PostAuthor: Blackfox » Fri Aug 05, 2011 4:01 pm
I had this to happen on my bike when i picked up a set of carbs off a friend the mixture screws where over tightened and it messed up the seats of them and one of the tips was broke off in the carb body
Fox
