73 Z1 TRIKE
jimmock
73 Z1 TRIKE
#1 PostAuthor: jimmock » Sat Aug 20, 2011 7:05 pm
Guyz,
After giving it many months of thought and running it past Big Fer and Ian Marshall, I have decided to "trike" my beloved Jaffa Z1. (Them Jaffas geeze me an 'ardon).
I wondered what was the best rear axle to use??
Any advice??
Jimmock.
Jimmock. :wnkr
I hate people I don't like !
Mark Tiller
#2 PostAuthor: Mark Tiller » Sat Aug 20, 2011 7:26 pm
Jaffas are not for "triking"....take yourself outside and slap untill the urge goes
07962421462
Re: 73 Z1 TRIKE
#3 PostAuthor: kev edwards » Sat Aug 20, 2011 7:29 pm
jimmock wrote:Guyz,
Any advice??
Jimmock.
Me thinks someone would beat you to death with something long and hard if you did Jim. :lol:
kas750
Re: 73 Z1 TRIKE
#4 PostAuthor: kas750 » Sat Aug 20, 2011 7:34 pm
jimmock wrote:Guyz,
Any advice??
Jimmock.
Superb idea Jim!...you really are going to break new ground with this one.
I believe reliant robin or the now collectible regal will provide a neccessary rolling chassis,although it would be a shame to ruin one of these tamworth icons by furnishing it with the running gear from a z1.
irhobotolo
Re: 73 Z1 TRIKE
#5 PostAuthor: irhobotolo » Sat Aug 20, 2011 7:41 pm
jimmock wrote:Guyz,
Any advice??
Jimmock.
Put the bottle away Jim :shock:
jimmock
Re: 73 Z1 TRIKE
#6 PostAuthor: jimmock » Sat Aug 20, 2011 8:12 pm
kas750 wrote:
jimmock wrote:Guyz,
Any advice??
Jimmock.
Kas,
I did consider the reliant rear axle (as that is the trikers no.1 choice).
It does mean getting the tubes cut and shortened. I have already made an "angle drive" to go from chain input through 90 degrees to shaft output. So this would allow me to use any rear axle with conventional flange input. I was considering the LSD axle from a capri but they cost £350 plus. The gearing is really long with a ratio of 3.05:1. Again it requires the cutting operation.
I have a rear axle from a V8 Scania tractor unit at hand. It has the bus diff fitted to allow a top speed of about 90mph (before speed limiters). This would mean running 22.5 inch wheels on the rear. This might be unstable at higher speeds.
Whats your thoughts on this???
Jimmock.
Jimmock. :wnkr
kas750
Re: 73 Z1 TRIKE
#7 PostAuthor: kas750 » Sat Aug 20, 2011 8:22 pm
jimmock wrote: This would mean running 22.5 inch wheels on the rear. This might be unstable at higher speeds.
Jimmock.
super singles :?:
#8 PostAuthor: zed1015 » Sat Aug 20, 2011 8:47 pm
You could save yourself some fabrication by running a sprocket off the reliants crown wheel and keep the chain drive (remember though to keep the diff packed with grease) then there is no need to shorten the left side axle shaft as the diff can remain in a central position.
Another popular option with the wannabe bikers is the Jag diff which has the added benefit of wishbone suspension and with the aid of some tastefully modified old bed angle you could utilse the original zeds shock mounts.
Fred
hi
#9 PostAuthor: Fred » Sat Aug 20, 2011 8:49 pm
JIMMOCK / KAS750
What a pair of twats :lol: :lol: :lol:
FFFFred
Always in front
69 KO 71K1 K6 F2 F1 CB1100F CB900F 74Rickman810 MotoMartinCB950 CB7/11 HarrisCB1100KB 90%Spencer Superbike and a Dax 70
Garn 1
#10 PostAuthor: Garn 1 » Sat Aug 20, 2011 10:56 pm
Not the Jaffa. Please re-think!
RegardZ
jimmock
Re: hi
#11 PostAuthor: jimmock » Sun Aug 21, 2011 5:03 am
Fred wrote:JIMMOCK / KAS750
FFFFred
Fred, you are right. Me and Kas are members of TWATS....
The World Association of Trike Specialists.
Membership details can be obtained from either of us at below...
jimmythetrike@twats.com
kasthreewheels@twats.com
I hope this helps.
Jimmock.
Jimmock. :wnkr
Fred
HI
#12 PostAuthor: Fred » Sun Aug 21, 2011 8:44 am
Nice one :fnee
FFFFFred
Always in front
doebag
#13 PostAuthor: doebag » Sun Aug 21, 2011 3:00 pm
Of course, you could always use a Z1000ST quote: worst shaft bike bike Kawasaki ever made as the basis, save all that aggro of joining chain drive to shaft drive :wink:
'Dying a'int much of a living, boy'
Outlaw Josey Wales
Member No. 555
RB
Mine's a triple!
Re: 73 Z1 TRIKE
#14 PostAuthor: RB » Sun Aug 21, 2011 8:50 pm
kas750 wrote:one of these tamworth icons
http://www.youtube.com/watch?v=QQh56geU ... 5417F78030
Lifes too short . . .
toycollector10
#15 PostAuthor: toycollector10 » Tue Sep 06, 2011 5:49 pm
Trike a '73 Z1?
This must be a wind up.
If it isn't, step away from the bike and go and find something else to mangle.
Cheers....
Users browsing this forum: sockpuppet and 42 guests
