Or i could try to get that old TL125 from my neighbour.
Project ?
Project ?
After seeing all the threads I am tempted to start something. I've the engine, well most of it. Z2 thats got a 903 barrel & head. Hopefully whoever did this changed the crank otherwise the comprression might be a bit low
Just got to get everythig else. Leaves alot of scope.
Pigford wrote:I was "mis-informed" (not intentional tho')![]()
I do have a Z650 frame + V5 with front ends (a std Z900 & a BANDIT 1200 RWU) with rear end (std Z1000 & BANDIT 600 - 160 section tyre) and tank/tail piece and brakes & down pipes, etc, etc....
whats the idea of a bandit swing arm? is it a straight fit?
Life is not a trial run
