head bearings
ZED1-18again!!
head bearings
Hi all, was wondering what advantages taper roller bearings have over stock ball-bearings, when fitted to zeds steering heads?? And how easy to fit them?
Hi, the advantage is the working surface of a roller is much larger than of a ball so the taper bearing should last much longer, I did mine last year and the job was easy, plenty of sets on the market but not many that have dust seals included, I got AllBalls brand wit the seals, I've heard tapers might be difficult to remove but considering the design there should be no need
- DogsbolloxofZ1B
Doddle to remove old races i use a rounded,flattened steel bar to drift out old races,the ideal way to fit new ones is a set of plastic bearing drifts but a piece of hardwood works ok,i reckon its a very worthwhile mod and have done it on both of my zeds the standard set up is ok for pushbikes
PAULJAC47 wrote:Doddle to remove old races i use a rounded,flattened steel bar to drift out old races,the ideal way to fit new ones is a set of plastic bearing drifts but a piece of hardwood works ok,i reckon its a very worthwhile mod and have done it on both of my zeds the standard set up is ok for pushbikes
If the outer race is upside down there is nothing to put the bar onto.
As the inner race is in situe i am going to use a socket which is slightly narrower than the stock tube
And a Lump hammer
Z1000 MK2
Z1300 DFI
Z1300 DFI
