cylinder head
DavidZ1R
cylinder head
#1 PostAuthor: DavidZ1R » Wed Jan 25, 2012 6:46 pm
Bit of advise please, took the head off my 250 engine, the pistons and head are covered in carbon, got new pistons and rings, can I use a wire brush on a drill to clean the head, or is that a big no no ?
#2 PostAuthor: Pigford » Wed Jan 25, 2012 6:51 pm
Don't use a steel wire brush - too agressive... :??
Soft brass is OK - or carefully scrape with a flattened copper tube or summink softer than alluminium if possible :wink:
#3 PostAuthor: zed1015 » Wed Jan 25, 2012 6:58 pm
Pigford wrote:Don't use a steel wire brush - too agressive... :??
+1 :up
LTD Project
#4 PostAuthor: LTD Project » Wed Jan 25, 2012 7:00 pm
Wire brush and dettol.... :lol:
You don't say how bad (caked hard) it is but if not too bad then you could try some fine(ish) wire wool and redex, dont forget the latex gloves.
sid123
#5 PostAuthor: sid123 » Wed Jan 25, 2012 7:15 pm
Soak in nitromores paint stripper then rinse off - no risk of scratching and comes clean
Sid
whoosh im gone
Users browsing this forum: Bing [Bot] and 57 guests
