piston sizes
piston sizes
a bit of info needed lads and lasses,ive just measured a standard piston(903cc)its about 65.16mm.ive been offered some pistons at 67.05mm.what cc would they be for.
Short answer: around 950cc
Long answer:
It's the area of the bore times the swept volume
so for a standard 6.6cm bore (piston is a bit less) and standard 6.6cm stroke....
for your 6.7cm pistons its...
but that's not allowing for any piston/bore clearance so add 1 mm (not actually sure what the bore should be for your pistons) and that makes it:
Long answer:
Code: Select all
(((bore/2)^2* pi) * 4) * strokeso for a standard 6.6cm bore (piston is a bit less) and standard 6.6cm stroke....
Code: Select all
(((6.6/2)^2*3.1415)*4)*6.6 = 903.16 ccfor your 6.7cm pistons its...
Code: Select all
(((6.7/2)^2*3.1415)*4)*6.6 = 930.74 ccbut that's not allowing for any piston/bore clearance so add 1 mm (not actually sure what the bore should be for your pistons) and that makes it:
Code: Select all
(((6.8/2)^2*3.1415)*4)*6.6 = 958.73 cc
i understand that ruffle,my mate has lent me some barrels that are one mm overbored,so can take a measurement off them to get correct bore.cheers.
i think they will be two mm overbore,and not one,as the piston i have here is one mm over,and reads 66.9 mm.
