new Std. size Piston rings - Recommendations
Z.O.A
#1 PostAuthor: Z.O.A » Thu Mar 22, 2012 8:42 pm
Just doing a freshen up of the the cylinder head on my A4 and while I have the head off I am going to give the bores a light hone and replace the piston rings, motor was still making good compression (I believe this will be first overhaul as the engine had only 25k on it when I imported it) but they're getting done anyway.
From experience, does anyone have any recommendations on what type or brand to get, I will be buying from the states as Prices in the UK are ridiculous, I found two types on Z1 Enterprises site.
http://www.z1enterprises.com/66mm-Kawas ... -4336.aspx
http://www.z1enterprises.com/66mm-Pisto ... 0-193.aspx
Any info appreciated, Cheers, Gavin.
#2 PostAuthor: zed1015 » Thu Mar 22, 2012 9:27 pm
I'd go for the first set but it says they are out of stock.
Second set looks cheap and the oil ring expander looks crude with very few concertinas.
If i had to use the second set i would probably use the expanders from the old rings,
PAULJAC47
#3 PostAuthor: PAULJAC47 » Thu Mar 22, 2012 9:50 pm
If engine is making good compression would advise against fitting non Kwak rings just for the sake of it,25k is not high miles on these motors,just my ten pennorth..Paul J
#4 PostAuthor: zed1015 » Fri Mar 23, 2012 11:26 am
PAULJAC47 wrote:If engine is making good compression would advise against fitting non Kwak rings just for the sake of it,25k is not high miles on these motors,just my ten pennorth..Paul J
True.
Users browsing this forum: Google [Bot] and 40 guests
