z1000a regulator/rectifier
j.b
#1 PostAuthor: j.b » Thu Mar 22, 2012 9:48 pm
does anyone have a wiring diagram to show how to convert the seperate regulator and rectifier to a combined unit from a later bike on an early z1000a?
cheers
PAULJAC47
#2 PostAuthor: PAULJAC47 » Thu Mar 22, 2012 9:55 pm
Just take the three outputs from the Genny/Alternator usually yellow to the three yellow inputs on the conbined unit any order round,red and white to the battery positive,brown to the trigger wire i usually use the live side of the brake switch,black to the frame,some units are five wire and dont have the brown wire,H**** wet dream cx 500 work well...at little cost.look for around 14.6 v dc across battery at 3k revs..Cheers Paul J
Big Fluff
Re: z1000a regulator/rectifier
#3 PostAuthor: Big Fluff » Fri Mar 23, 2012 9:14 am
j.b wrote:does anyone have a wiring diagram to show how to convert the seperate regulator and rectifier to a combined unit from a later bike on an early z1000a?
cheers
Jon - If you need a hand just give me a call and I'll fit it for you.
Regs, Will.
j.b
#4 PostAuthor: j.b » Fri Mar 23, 2012 8:15 pm
nice one, cheers paul :D
and many thanks Will, i think i'll be ok....all them wires were confusing me and i was sure it should be more complicated ....will give it a go, whats the worst that can happen (its not my bike) :lol:
