Clocks from Z750 Twin
FreddaAbborre
#1 PostAuthor: FreddaAbborre » Mon Mar 26, 2012 7:13 pm
Can I use clocks from a Z750 twin on my Zed? The max limit is 220km/h and 10krmp. Is the angle of the needle the same; so I can use new faces showing 240/12krpm?
Z1 Moto Martin
Z1A
Z1000 A2
Husaberg FE350
Big Fluff
Re: Clocks from Z750 Twin
#2 PostAuthor: Big Fluff » Tue Mar 27, 2012 12:16 pm
FreddaAbborre wrote:Can I use clocks from a Z750 twin on my Zed? The max limit is 220km/h and 10krmp. Is the angle of the needle the same; so I can use new faces showing 240/12krpm?
Post a pic and either I or Al Marshall can tell you.
Will.
FreddaAbborre
#3 PostAuthor: FreddaAbborre » Tue Mar 27, 2012 6:59 pm
Will.
Here's a pic. Not the best one, havn't bought the clocks yet.
Z1 Moto Martin
Z1A
Z1000 A2
Husaberg FE350
Big Fluff
#4 PostAuthor: Big Fluff » Wed Mar 28, 2012 5:23 pm
The speedo (same as Z650) will be fine, and I can provide you with a MPH dial kit to go over the top of the KMH faces.
The rev-counter should be okay as I believe it's the cam gear ratio that's different on the Z750 twin head. i.e. although Z1 to Z1000A2 rev-counter faces read up to a max of 12000rpm, it should still read correct, but ending earlier at the 10000rpm.
will.
FreddaAbborre
#5 PostAuthor: FreddaAbborre » Wed Mar 28, 2012 6:32 pm
Big Fluff wrote:The speedo (same as Z650) will be fine, and I can provide you with a MPH dial kit to go over the top of the KMH faces.
will.
But are the clocks basically the same as clocks for Zeds, but with lower max-gradings?
I'm in Sweden so I would change the faces (10krpm/220km/h) to faces for Z1 (12krpm/240Km/h).
Z1 Moto Martin
Z1A
Z1000 A2
Husaberg FE350
Big Fluff
#6 PostAuthor: Big Fluff » Thu Mar 29, 2012 5:39 pm
As for the 'workings' inside, Al Marshall would be your best contact. Will
Keefleaf
#7 PostAuthor: Keefleaf » Thu Mar 29, 2012 10:17 pm
If they both drive off 19" wheel then the gearing should be the same..I guess.
