Hi looking for a set of valves.does not mater if they have been shortened[with in speck]but must be goog condition.
I would like to borrow a shim tool if someone has one.
Please do not offer unless you will send.I was offered these before but after over a month and lots of they will be in the post,i still do not have them.And i would like to get the bike back on the road.
THANKS FOR ANY HELP
valves and shim tool
keep thoses wheels turning
- Ginger Bear
I've used these in the past with no problems, you'll find there is also a lot more meat on the seating face, that will help get your clearances back into the larger shim sizes.
https://www.z-power.co.uk/merchantmanag ... cts_id=179
ZPower also have them listed on evilbay at a much cheaper or best offer price.
http://www.ebay.co.uk/itm/KAWASAKI-Z1-Z ... 35b757002c
Can't go wrong for that. Bargain.
valves
I would'nt ponce around with second hand valves which will probably need re-faceing anyway,and £60 for 8 new valves from evilbay/z-power is the way forward. if you need seats recut,I have a full set of seat cutters and this is a job i have done many times. BUZZARD
Every man should have a shed (for bikes obviously..)
