engine a bit rattly[SORTED]
zman
#1 PostAuthor: zman » Wed May 02, 2012 11:20 am
Ive just rebuilt the top end.When its cold it sounds like a bag of bolt :(
but when up to temperature all seams to settle down.will this settle down when all is bedded in or do i need to investigate :?:
has any one got any thoughts on this.
keep thoses wheels turning
#2 PostAuthor: zed1015 » Wed May 02, 2012 12:29 pm
Hard to comment without hearing it.
Double check the camchain tensioner and valve clearance will need re-checking after first heat cycle along with re-torqueing the head.
pertonpc
#3 PostAuthor: pertonpc » Wed May 02, 2012 1:53 pm
Hi Mate
It shouldn't sound like a bag of bolts after a rebuild. Was this noise there at all before the rebuild?
Can you get a video clip onto youtube or get a member nearby to have a listen for you?
Are the carbs fairly balanced and do you get reasonable hot compression readings and similar plug colours across the four?
Does the bad sound seem to come from top or bottom of the engine and any particular side?? I believe you can use a metal rod to your ear if you don't have a mechanics stethoscope to borrow.
Fingers crossed it's nowt major - from Mark
zman
#4 PostAuthor: zman » Wed May 02, 2012 3:58 pm
It was cam chain tensioner.
the bolt that locks the sprung arm into place was almost stripped.So the rod was moving.helicoiled thread and now sorted.
after getting the shims is it likly they will have to be changed again after first run :?:
Thanks for your help
#5 PostAuthor: zed1015 » Wed May 02, 2012 4:30 pm
I always run my engines up after a build with the cam cover held on with just a few bolts.
Then leave overnight, re-torque the head and re-check the shims cold.
They usually don't move much but running the motor does allow everything to settle especially if new valves etc have been fitted..
I would double check the cam timing anyway if the tensioner was loose to be 100% the chain hasn't jumped a tooth.
I just had a head in with 8 bent valves from exactly the same tensioner fault.
