carb vacuum
zman
carb vacuum
#1 PostAuthor: zman » Sat May 12, 2012 4:39 pm
Set the carbs with vacuum gage and could only get them balanced at around 27.
What are the implications of this if any :?: thanks
keep thoses wheels turning
#2 PostAuthor: zed1015 » Sun May 13, 2012 6:28 pm
Doesn't matter what the reading is as long as they are all the same.
#3 PostAuthor: Al » Sun May 13, 2012 6:38 pm
As Rob says above, some small changes in cam timing amongst other things can explain differences in idle vacuum. A much lower value than 27 may give rise to poor idleing but i suspect yours' is as regular as anything. 22 springs to mind as a basline value for standard set-up.
zman
#4 PostAuthor: zman » Mon May 14, 2012 7:41 am
Thanks for replies.will leave as is.
idling well :)
