Z900/1000 CAM LIFT ADVICE
#1 PostAuthor: Pigford » Tue May 22, 2012 7:11 pm
Can someone tell me how much actual LIFT the standard cams have.... thats the lobe dimension less the narrowest section.
I know thats not always the actual lift value, but it's all I need ta :wink:
hillbilly
#2 PostAuthor: hillbilly » Tue May 22, 2012 7:30 pm
on mine its 8mm. :wink:
#3 PostAuthor: Pigford » Tue May 22, 2012 7:35 pm
OK - fanx - just got a set with 9.5mm :wink:
hillbilly
#4 PostAuthor: hillbilly » Tue May 22, 2012 7:59 pm
i have some 11.5 ones. :shock:
#5 PostAuthor: Pigford » Tue May 22, 2012 8:07 pm
Mine 9.5 INCHES :bla
Re: Z900/1000 CAM LIFT ADVICE
#6 PostAuthor: zed1015 » Tue May 22, 2012 9:18 pm
Pigford wrote:Can someone tell me how much actual LIFT the standard cams have.... thats the lobe dimension less the narrowest section.
Std cams = 8.4mm.
