vesrah gaskets
tricky
vesrah gaskets
#1 PostAuthor: tricky » Tue Jul 31, 2012 1:47 pm
hi all does anyone know if vesrah gasket sets are still available?
have tried a couple of places localy but nothing so far, if not available anymore, what aftermarket brand is considered good quality, thanks in advance for any info, tricky.
#2 PostAuthor: z1bman » Tue Jul 31, 2012 2:43 pm
z power do them
Jerry
President
President
#3 PostAuthor: Jerry » Tue Jul 31, 2012 7:22 pm
Never had a problem with any of the aftermarket gaskets available - despite the rumours!
KeithZ1R
#4 PostAuthor: KeithZ1R » Tue Jul 31, 2012 8:53 pm
Think Germany bought em all you can get them pretty readily from there :)
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
hutch
gaskets
#5 PostAuthor: hutch » Wed Aug 01, 2012 6:40 am
I SELL EM .
Big Fluff
#6 PostAuthor: Big Fluff » Wed Aug 01, 2012 2:41 pm
Dont fit the valve stem seals that are in the Vesrah kit, they're about as much use as "tits on a fish" :no
The gaskets are generally good, but I would suggest fitting decent stem seals from Ray Debbens if you don't want your bike to look like it's on 20 Woodbines a day. :lol:
Charlie
#7 PostAuthor: Charlie » Wed Aug 01, 2012 4:33 pm
I've never had a problem with Vesrah stem seals and I have used at least 3 sets on 3 different bikes ....(two Z650's and a GS750)
Vesrah source all their parts from the OE manufacturers in Japan, that's why they are always so good.
prowlerz1
#8 PostAuthor: prowlerz1 » Wed Aug 01, 2012 9:13 pm
how much is a full kit for z1a/b/900 hutch ???
73 z1 green
73 z1 brown
74 z1a brown
75 z1b red
75 z1b blue
76 z900 green
77 z1000 black
Zrx1200r
KeithZ1R
#9 PostAuthor: KeithZ1R » Wed Aug 01, 2012 9:16 pm
Im with Charlie never had a problem with Vesra stem seals and I too have fitted several sets over the years on different engines
Keith
:bop :gom
mistaken.
Big Fluff
#10 PostAuthor: Big Fluff » Thu Aug 02, 2012 11:57 am
The stem seals in the Vesrah kit I got a few months back were so flimsy you couldn't even fit them!
The wire clip (not a coil wound item) simply fell off.
Sorry but I would consider at least the ones that came in my kit, absolutely dreadful.
Maybe I got a bad set, but all I would say is check first!
#11 PostAuthor: zed1015 » Thu Aug 02, 2012 3:29 pm
They used to be green stem seals with a twice wound coil near the base (as well as the spring round the top) which worked well.
Maybe they changed suppliers.
Last few gasket sets have been ATHENA which are very good.
The Athena group of companies now supply a lot of leading race teams and aftermarket big bore kits for motocross tuners Renaldi which are as renowned in the motocross world as moriwaki and yoshimura are on the race track.
Athena sets go for around £60 / £70 - ish.
I know a trade rep who might go for a bulk order but won't know if he'd be up for it till i ask.
GEZ635
#12 PostAuthor: GEZ635 » Fri Aug 03, 2012 8:09 pm
Nothing compares to original valve seals and gaskets. I am building 900/1000 engines all the time and would never compromise a build for a few quid on gaskets. Same goes for piston rings. The cheap ones from america are no where near the quality of the originals. Original is more expensive but I would rather build it once. If you are someone who does 100 miles a year then it probably wont matter using cheap shit but if really want to ride then use quality.
Gez
Gez
Garn 1
#13 PostAuthor: Garn 1 » Sat Aug 04, 2012 3:43 am
Jerry wrote:Never had a problem with any of the aftermarket gaskets available - despite the rumours!
I have had trouble, mainly to do with the thickness of the head gasket. I have found them to vary in the order of 0.5mm. Now this isn't much, however when you combine it with a tunnel rubber that is undersize, or is in a slim batch of aftermarket rubbers, you can get into trouble with oil leaks around the head tunnel.
Hence, I always look and reject any head gasket that measure too thick, albeit, they look to be the answer!
RegardZ.
