Single front disc brake master cylinder
- Paul Whitehouse
Anyone got a front master cylinder for a single front disc setup for a zed?...not too bothered if it needs refurbishing. I'm building a `77 Z1000 special (Long, Low, Mean and Nasty...another drag zed in the projects section) and am only running a single disc setup to keep the look as period as possible for a drag bike. Cheers.
If it's too loud....too bad.
- Mark Stratton
There's some repros avail on ebay etc. from about £60ish for single disc.
If you don't have one to repair they might be a cheaper option as you won't need new internals and they come with bar clamps and lever. Have a look.
It's expensive and fiddly to replace the internals.
From Mark
From Mark
- Paul Whitehouse
Hi Chaps....thanks for the info. Mark (Pertonpc)...I've found the single disc ones on ebay for £62.00....up till now I'd only found the ones that were £90.00 !!!!....I've now purchased one of these...others had warned me that refurbishing one was a bit of a nightmare !!!!....thanks, Paul.
- Mark Tiller
