Any input appreciated
Converting a Spectre/ST to chain
Just wondering how much work would be involved or if indeed it would be worth it cost wise
- sockpuppet
Gpz output shaft (better than a J as it uses a large nut for the sprocket retention insread of a bolt)
Is this a Unitrak Gpz shaft ?
Its just that i have two GPZ1100b2 `s and both have the bolt type ,
and world`s most complex retaining washer system !!!!
Regards
Mick
Regards
Mick
sockpuppet wrote:Gpz output shaft (better than a J as it uses a large nut for the sprocket retention insread of a bolt)
Regards
Mick
Ah. yes! a unitrac one.
Thanks guys
Thanks for the comprehensive reply Zed
Looks like this will be a viable project
zed1015 wrote:For the J style non kickstart engine .
You need -
gpz/j gear selector shaft.
gpz/J inner cover/seal holder.
gpz/J sprocket cover.
Looks like this will be a viable project zed1015 wrote:sockpuppet wrote:Gpz output shaft (better than a J as it uses a large nut for the sprocket retention insread of a bolt)
Regards
Mick
But beware, you can't use the input-shaft, as it's longer. Just did this with my Z1000J, because I got hold of a set of Z1100ST cases and you just swap all the bits from the J to the ST and voila you have a beautiful engine.
Cheers,
Greg
