z650 choke railm
z650 choke railm
Doe's anyone have a choke plunger lifting arm for 77b1 z 650 its the end arm that lifts the choke plunger right hand side?.
Cheers john.
Cheers john.
Try John Browse at Wrexham if you are struggling to get one on here.
Where did yours vanish to?
Johno
If you can find the part number for the bit you need I will check which other models and years used it. You may find it easier to get a complete carb from a less popular model that uses the same lifter.
Pretty complete 650 carbs also come up on eBay from time to time if you keep your eye on that.
Try a pm to Crofty or Guyzed on here? they have 650 some bits.
From Mark
From Mark
Hi Guyz,
Can't find the number Guy mentioned on my list.
If what you want is no. 47 on this diagram -
http://www.cmsnl.com/kawasaki-1978-kz65 ... ml#results
then it is part ref 13168-1026 called a lever, starter plunger
which came fitted to these bikes -
Model (25):
KZ1000-A1 (KZ1000) (1977)
KZ1000-A2 (KZ1000) (1978)
KZ1000-A2A (KZ1000) (1978)
KZ1000-A3 (KZ1000) (1979)
KZ1000-A3A (KZ1000) (1979)
KZ1000-A4 (KZ1000) (1980)
KZ1000-B1 (KZ1000 LTD) (1977)
KZ1000-B2 (KZ1000 LTD) (1978)
KZ1000-B3 (KZ1000 LTD) (1979)
KZ1000-B4 (LTD) (1980)
KZ1000-C1 (Police 1000) (1978)
KZ1000-C1A (Police 1000) (1978)
KZ1000-C2 (Police 1000) (1979)
KZ1000-C3 (Police 1000) (1980)
KZ1000-C4 (Police 1000) (1981)
KZ1000-D1 (Z1R) (1978)
KZ1000-D3 (Z1R) (1980)
KZ1000-E1 (Shaft) (1979)
KZ1000-E2 (Shaft) (1980)
KZ650-E1 (LTD) (1980)
KZ650-F1 (1980)
KZ650-H1 (CSR) (1981)
KZ900-A4 (1976)
KZ900-A5 (1977)
KZ900-B1 (LTD) (1976)
Model (25):
KZ650-F1 (1980)
KZ900-A4 (1976)
KZ900-A5 (1977)
- Ginger Bear
johno wrote:guy are there any meets or shows coming up?
cheers john
John, Looks like a few of the 'usual suspects' might be here;
http://www.z1ownersclub.co.uk/forum/vie ... hp?t=22711
