Z900 SWING ARM PIVOT WIDTH
london calling
#1 PostAuthor: london calling » Thu Jan 24, 2013 6:46 am
What is the swing arm pivot width for a Z900 :?:
Also is this the same for the Z1000 models including Z1R and MK.2 :?:
Jack
LondonZ1
#2 PostAuthor: LondonZ1 » Thu Jan 24, 2013 8:47 am
Jack, I can measure mine tonight if you don't get an answer before then. I know that the Z900 pivot width is the same as the Z1/A/B as the same sanctuary arm fits both Z1 and Z900.
KWACKERZ1
#3 PostAuthor: KWACKERZ1 » Thu Jan 24, 2013 8:48 am
234mm for z1000a1 and MK2 Pretty sure z900 is the same as I have swapped dresda swing arms between 900's and 1000's.
#4 PostAuthor: zed1015 » Thu Jan 24, 2013 5:25 pm
It is more often than not 235mm between the frame bosses.
I have four frames here all 235mm.
Never had a straight frame vary by more than half a mill .
KWACKERZ1
#5 PostAuthor: KWACKERZ1 » Thu Jan 24, 2013 7:18 pm
I would concur with Rob i put that in from memory today but checking mine Robs right 235.
london calling
#6 PostAuthor: london calling » Thu Jan 24, 2013 9:49 pm
Many thanks ladz,most appreciated :wink:
Jack
KeithZ1R
#7 PostAuthor: KeithZ1R » Thu Jan 24, 2013 9:58 pm
Z1R/1000 230mm without end caps across the swing arm tube 235 inside between the frame boss's
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
