dust cover
dust cover
is the right hand side dust cover on a twin disc set up the same as a single disc only without the four bolt holes?
- Regular Poster
the two hole type that you have supplied the part no for will only fit the right side the speedo side looks like this
http://www.ebay.co.uk/itm/78-Kawasaki-K ... 337bdda750
- Regular Poster
this is getting confusing so full story, i am in the slow process of restoring a uk z900 a4 twin disc, few months ago i sent some bits to mikey for plating/chroming, the left side-speedo went to him but the right side got left behind. so as there seems to be right side dust covers on ebay quite regular i thought maybe i could get one and drill the 4 holes to make one if they are the same apart from the holes. hope it makes more sense.
these ones are a bit cheaper
http://www.ebay.co.uk/itm/KAWASAKI-Z650 ... 417048a627
this one bit more expensive but new
http://www.ebay.co.uk/itm/180914185767? ... 1423.l2649
