Will a GPZ750 motor fit into a z650 frame?
coldsummer
#1 PostAuthor: coldsummer » Wed Feb 20, 2013 10:49 pm
As per title, does anyone know if the GPZ750 R1 (earliest one) fit into a Z650 frame?
If the answer is yes, would the std 650 carbs be compatible dimension wise?
Cheers for any answers.
KeithZ1R
#2 PostAuthor: KeithZ1R » Wed Feb 20, 2013 11:08 pm
Just seen one with a turbo engine in so it must be feasible
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#3 PostAuthor: zed1015 » Thu Feb 21, 2013 12:38 am
All 750 motors are based on the 650, even the Zephyrs .
Carb spacing is the same.
Much like the 900/1000/1100 development they didn't change much so most engine parts are interchangable.
#4 PostAuthor: ADRIAN H » Thu Feb 21, 2013 2:10 pm
I have seen GPZ1100 engines in Z650 frames. The way to go . .. .. .. .. .. :D
#5 PostAuthor: Ginger Bear » Thu Feb 21, 2013 5:49 pm
Mmmmmm......
What have you got planned now then Simon :?
coldsummer
#6 PostAuthor: coldsummer » Thu Feb 21, 2013 6:21 pm
Thank you gents, you are A-mazing :D
I'll let you know soon Steve :wink:
irhobotolo
#7 PostAuthor: irhobotolo » Thu Feb 21, 2013 9:10 pm
ADRIAN H wrote:I have seen GPZ1100 engines in Z650 frames. The way to go . .. .. .. .. .. :D
but only in a straight line .... :wink:
#8 PostAuthor: ADRIAN H » Thu Feb 21, 2013 9:31 pm
think this will go around corners. :D :D :D :D :D
http://www.z1ownersclub.co.uk/forum/vie ... sc&start=0
Users browsing this forum: Bing [Bot] and 69 guests
