dyna coils
sp.milne
dyna coils
#1 PostAuthor: sp.milne » Fri Mar 01, 2013 2:41 pm
Hi all
Had the tank off today to set the valve shims, noticed both coils are trying to divide in half. Though not ideal the bike still runs OK, did have a issue with it cutting out while sat in traffic on a very hot day. Do you think it is coil related as both would have to go down at the same time. The bike has electronic ignition and I was suspecting this to be the problem.Any help would be much appreciated
If as I suspect that the coil's have seen better days has any one got a pair they would like to sell
Thanks Stuart
#2 PostAuthor: z1bman » Fri Mar 01, 2013 2:45 pm
new coils required there surprised it is running at all
weaver
#3 PostAuthor: weaver » Fri Mar 01, 2013 3:03 pm
new ones required,why have they gone like that,dodgy installation?
#4 PostAuthor: Ginger Bear » Fri Mar 01, 2013 4:51 pm
I'd be interested to see if spacers were used between the coils & frame mounts. If they weren't, then bolting them directly to the frame without spacers will distort the steel/iron bar & hey presto.....
#5 PostAuthor: zed1015 » Fri Mar 01, 2013 5:04 pm
Ginger Bear wrote:I'd be interested to see if spacers were used between the coils & frame mounts. If they weren't, then bolting them directly to the frame without spacers will distort the steel/iron bar & hey presto.....
I agree.
Definately stress cracks to open like that.
If they are still working just fill the gap with some nail varnish or similar , fi glass resin etc and then release the mounting bolts to let the gap close and seal ,then refit with some washers under spacers to lift the body clear of the frame.
Should be good for a few more years use after that.
#6 PostAuthor: Ginger Bear » Fri Mar 01, 2013 5:20 pm
Spacers work like this;
#7 PostAuthor: Pigford » Fri Mar 01, 2013 5:52 pm
As Rob says - fill the gaps & should be fine.
Modern Bandit coils are pretty damned good apparently :wink:
PaulMceleney
Chunks
#8 PostAuthor: PaulMceleney » Fri Mar 01, 2013 6:29 pm
The bike will also cut out if the coils are not tight to the frame after about 30 miles ,this was happening to me on my z1000, and i kept thinking the engine was getting to hot but this was not the case
sp.milne
#9 PostAuthor: sp.milne » Fri Mar 01, 2013 7:14 pm
Thanks lad will get my nail varnish out ! Now were did I leave it. :lol:
Garn 1
#10 PostAuthor: Garn 1 » Fri Mar 01, 2013 7:39 pm
Sp.Milne, you didn't confirm that the coils were, indeed, incorrectly mounted as Ginger bear suggested. I can't think of any other reason the coils would have cracked like you have shown.
There must be a good commercially available electrical insulation you can paint on, other then your nail vanish/ polish!
RegardZ.
PAULJAC47
#11 PostAuthor: PAULJAC47 » Fri Mar 01, 2013 8:09 pm
Hi Stuart,i would use Araldite or a similar resin based two part adhesive,Cheers
Paul J
wilsonsjw11
#12 PostAuthor: wilsonsjw11 » Fri Mar 01, 2013 8:20 pm
Was the spacer removed because of the close proximity to the terminals where everyone usually fits heatshrink to prevent shorting onto the spacer.
Regards
Steve
sp.milne
#13 PostAuthor: sp.milne » Fri Mar 01, 2013 10:05 pm
Just had a quick look at the mount's, they look the same as the bear's pic's. At a lose to see why they cracked.
If you look close at my first pic you can see ths spacer
#14 PostAuthor: z1bman » Fri Mar 01, 2013 11:06 pm
could this be the guy that fitted your coils ?
http://www.kzrider.com/forum/4-electric ... ize=larger
sp.milne
#15 PostAuthor: sp.milne » Sat Mar 02, 2013 9:16 am
[quote="z1bman"]could this be the guy that fitted your coils ?
Could well have been! I've had the bike for around 8 or 9 years & they did'nt
Look new then.
