Wellseal
weaver
Wellseal
#1 PostAuthor: weaver » Thu Mar 21, 2013 8:21 am
is it worth using the above on base and head gaskets on my elr?
thanks
Big Fluff
Re: Wellseal
#2 PostAuthor: Big Fluff » Thu Mar 21, 2013 3:51 pm
weaver wrote:is it worth using the above on base and head gaskets on my elr?
thanks
Loctite 3020 is better.
#3 PostAuthor: zed1015 » Thu Mar 21, 2013 6:34 pm
What kind of gaskets ?
You need the loctite for copper but not on on the ordinary fibre/paper type where a bit of sealer front and back of the camchain tunnel and around the cam end plugs is all that should be needed.
weaver
#4 PostAuthor: weaver » Thu Mar 21, 2013 7:01 pm
just the standard gaskets,cheers
#5 PostAuthor: zed1015 » Thu Mar 21, 2013 9:03 pm
On base gaskets i grease both sides (no sealer).
This helps the the gasket settle evenly when being tightened,makes for easier removal at a later date and helps prevent oil seepage and the wick effect by sealing the surface.
weaver
#6 PostAuthor: weaver » Thu Mar 21, 2013 9:32 pm
thanks for the info :wink:
