csr1000 carb change
stevie g
csr1000 carb change
#1 PostAuthor: stevie g » Mon Apr 08, 2013 9:25 am
Hi Guys, can I fit z1000 st carbs on my CSR1000 without any probs as the CSR carbs are diaphragm and st are slide I think, thanks $tevie. :jake
stephen g mackay
#2 PostAuthor: zed1015 » Mon Apr 08, 2013 9:42 am
Carbs will fit as they are the same spacing. you will have to swop the inlet manifolds too and maybe muck about with the throttle cables fitment.
The ST's 28mm carbs (or bored out 26's) are the smallest you need to take advantage of the J type heads bigger valves.
stevie g
#3 PostAuthor: stevie g » Tue Apr 09, 2013 4:39 pm
zed1015 wrote:Carbs will fit as they are the same spacing. you will have to swop the inlet manifolds too and maybe muck about with the throttle cables fitment.
OK thanks for that. I understand the changing manifolds bit but what has a J type head got to do with my CSR ? Are these the heads on mine ? and what do you mean by bored out 26's ? are they 26mm as standard and bored out to suit mine ? have to bear in mind I don't know a lot about the history of these bikes. cheers $tevie.
stephen g mackay
#4 PostAuthor: paul doran » Tue Apr 09, 2013 4:56 pm
Stevie Your CSR 1000 has a J type head fitted to it as standard
stevie g
#5 PostAuthor: stevie g » Tue Apr 09, 2013 5:07 pm
paul doran wrote:Stevie Your CSR 1000 has a J type head fitted to it as standard
Ah OK thanks Paul. What about the carbs thing 26mm out to 28 ? $
stephen g mackay
#6 PostAuthor: zed1015 » Tue Apr 09, 2013 6:54 pm
St carbs are 28mm so you will be ok.
26's can be bored out to 29.5 for extra performance.
stevie g
#7 PostAuthor: stevie g » Tue Apr 09, 2013 7:08 pm
zed1015 wrote:St carbs are 28mm so you will be ok.
OK. yea I've heard of people doing that before on aircooled RDs I think, from standard 28mm to 29 or 29.50mm. $
stephen g mackay
