Sump Removal?
njwmct
Sump Removal?
#1 PostAuthor: njwmct » Sat May 18, 2013 3:46 pm
Tried to remove the sump on my Mark 2
It won't budge.
Any tips or tricks that aren't going to damage the casings?
#2 PostAuthor: z1bman » Sat May 18, 2013 4:09 pm
give it a good couple of blows with a copper hammer at the sides preferably at the front part L + R side they are stronger than you would think . make sure the filter plate + all the bolts are removed first
#3 PostAuthor: chrisu » Sat May 18, 2013 5:11 pm
z1bman wrote:give it a good couple of blows with a copper hammer at the sides preferably at the front part L + R side they are stronger than you would think . make sure the filter plate + all the bolts are removed first
is the right answer..........
njwmct
Re: Sump Removal?
#4 PostAuthor: njwmct » Sat May 18, 2013 6:05 pm
njwmct wrote:Tried to remove the sump on my Mark 2
It won't budge.
Sorted! - thanks chaps
